Visitor hpbhat_grl
Enable only PMA in GTY transceiver
In the transceiver block, is there any option to enable only PMA block and Can I interface my own PCS implemented in FPGA fabric?
For example, I need to use 128B/132B encoding which is not supported by XCVR PMA and I need to use scrambling of different polynomial. In this case, I will implement the PCS in FPGA and want to send the encoded stream to PMA .
My targetting link rate is 20.625Gbps max.
With Regards,
Hariprasad
回复: Enable only PMA in GTY transceiver
hi @hpbhat_grl
May I get any document reference or example design which atleast explains how 64b66b or 8b/10b is mapped to 64 / 8 bit PMA?
Please look at UG578
http://www.xilinx.com/support/documentation/user_guides/ug578-ultrascale-gty-transceivers.pdf
Page 113 Figure 3-6 for 8b10b encoding, and page 254 Figure 4-30 for 8b10b decoding
Page119 Figure 3-7 for 64b66b encoding, and page 300 Figure 4-51 for 64b66b decoding
Boris
Re: Enable only PMA in GTY transceiver
The GT is a hardblock and so you don't have access to the PMA by itself.  You can choose to make no changes to the data in the PCS section and pass it in "RAW" mode to the fabric for your own processing.  Some IP does use the GT sucessfully in this manner.  The RAW mode of encoding is on the "basic" tab of the GT wizard.
Roy
hi @hpbhat_grl
when you customize the GT Wizard IP, you can disable the PCS features, so that only PMA is remained.
you can select encoder/decoder to be RAW. This will remove most of PCS features, e.g., comma align, channel bonding, clock correction, etc...
if you don't need the TX buffer and RX buffer, you can bypass them. This can reduce the latency and make sure the latency is deterministic. If you don't need to care about latency, you can leave them there.
Boris
Visitor hpbhat_grl
Is there any guideline document which helps me to interface custom PCS to PMA?
For example, PMA user data width is 128-bit. If I implement the 128b/132b encoding, thhen the data width becomes 132bit. How I can map 128bit to encoded 132bit?
Also, channel Bonding is part of PCS. How I can check the lane alignment in receiver side in my custom PCS?
With Regards,
Hariprasad
hi @hpbhat_grl
- the 128bit to 132bit converter is implemented in fabric logic. you can follow the protocol i think. what procotol is it?
- channel bonding is also implemented by fabric logic. the protocol should define some patterns for channel bonding.
Boris
Visitor hpbhat_grl
Hi @borisq ,
Protocol is USB3.1. Yes, protocol will tell the 128b to 132bit mapping.
Once encoded, I need to send the encoded data (132-bits) to PMA.
My question is how to interface that encoded 132bit to 128bit of PMA as PMA has the maximum 128bits data interface?
With regards,
Hariprasad
hi @hpbhat_grl
i think if the protocol tells 128b to 132b mapping, it should also tell the 132b to 128b mapping, or just tell it is just reversed, doesn't it?
Boris
Visitor hpbhat_grl
Protocol mentions both the encoding (128b to 132b) and decoding (132b to 128b).
For example, data flow for transmitter (which includes encoder only) looks something like this
User data in USB3.1 (128bit data width)-> 128b to 132b encoder (here, the data width would become 132bits ) -> PMA (128bit only)
In the receiver side, PMA (128bit) -> Decoder (132b to 128bit) -> User data in USB3.1 packets
So, my question talks about the data width mismatch highlighted in Red.
With Regards,
Hariprasad
hi @hpbhat_grl
in the RAW mode, the LSB is transmitted first and MSB is the last. also the LSB is received first and MSB is the last in receiver side.
if you want to send 132bit data beat, you can send 128bit in the current cycle and put the remaining 4 bits + 124bits of the next data beat in the next cycle.
like this way...
128bits
4bit+124bit
8bit+120bit
Boris
Visitor hpbhat_grl
Hi @borisq ,
I thought the same approach of interfacing the encoded data to PMA.
May I get any document reference or example design which atleast explains how 64b66b or 8b/10b is mapped to 64 / 8 bit PMA? 128b/132b is somewhat new . But, 10G uses 64b/66b and plenty of designs available. Just looking to get required info in the document to have the clear idea of the PCS to PMA path. (Currently I am checking 10G MAC subsystem IP)
With Regards,
Hariprasad
Visitor hpbhat_grl
Hi @borisq ,
I think I need to enable the gearbox to adapt data width of encoded data and PMA data width
hi @hpbhat_grl
Boris
