GTH TX to 75 Ohm coaxial cable @12Gbps
  Can anyone recommend a solution to interface GTH Tx to 75 Ohm coaxial cables @12Gbps?  And similarly for the other direction.  Either using active devices or passive networks.
  I have tried SDI and CoaxPress 12G transceivers, but IBERT test does not work over them.  I suspect their built-in reclocker function is line encoding sensitive and rejects the pseudo random data used for IBERT test.  CoaxPress uses 8B/10B and SDI uses its own scrambling algo.
Neo
Re: GTH TX to 75 Ohm coaxial cable @12Gbps
Assuming your looking at SDI video ?
have you looked at the SDI video dirver / receivers ?
e.g.   LMH1219
Hi John,
  I had tried Macom and Semtech SDI 12G TX and RX ICs.  I could not get IBERT link up with them.  I am sure the Macom SDI hardware is working because I can send 12G SDI video over them.  I am surprised when I switch to IBERT I can't even get a link up.
  Their datasheet mentioned it has built-in reclockers, so I suspect these ICs will detect for SDI standard's own line coding before turning on their outputs
Neo
Do you have the macom parts with the built in eye checker ?
thats normaly a good start point,
provided the iBert is at the correct clock frequency, why should not the buffers work ?
Hi John,
  My intent is to use SDI transmitter and receivers to send non-SDI data and to convert GT differential signals to 75 Ohm coax signals.  So I use FPGA IBERT as a test to see if these transceivers allows non-SDI signals to pass through.
  I believe besides frequency, SDI reclockers are actually line encoding sensitive.  I hope someone can confirm/refute this.
Neo
hi wtneo@leica
maybe you can check with Macom and Semtech to see if the PRBS pattern is allowed in the reclockers.
Boris
Hi Boris,
  Yeah working on that.  Meanwhile I am also asking if anyone knows of other solutions.
Neo
