GTH Transceiver data fifo clock issue
Hello Everyone,
Let me first introduce you with my design, Design has GTH transceiver & 2 FIFO, one FIFO at TX side & another at RX side.
DATA path:
40bit parallel data --> TXFIFO(40*256) --> GTH TX parallel data input port (40bit) -->  GTH transceiver serial line loopback (via FMC loopback)--> GTH RX parallel data output (40bit) --> RXFIFO
TXFIFO :  WR clock is 125 MHz (KCU105 kit) & RD clock txuserclk output of transceiver(125MHz)
RXFIFO :  WR clock is txuserclk output of transceiver(125MHz) & RD clock is 125 MHz (KCU105 kit)
We are passing fix data to TX FIFO input port.
Both FIFO gets reset with rx_reset_done signal comes from the GTH.
GTH starts to read from TX FIFO after 5 words written and in the same way at RX side design reads data from RX FIFO after GTH writes 5 words.
So the issue I am facing is both FIFO have the same clock frequency but the different source & we have taken care that after writing 5 words we start reading at both side of FIFO despite that the RXFIFO gets full frequently.
As per my understanding if the clock is the same for RD & WR than the ratio of 5 words should remain constant at RX SIDE.
Please guide me. Fill free to contact me for any requirement of further information.
Re: GTH Transceiver data fifo clock issue
Hello @eschidl
I glad to know you that the issue with FIFO is resolved with the following clock scheme.
Clock scheme:
1. External clock(125M) => IBUFDS_GTE3/O => GTH (125M)
                                  IBUFDS_GTE3/ODIV2 => BUFG_GT => Fabric logic(TX_FIFO_WR CLK & RX_FIFO_RD_CLK) (125M).
2.125M free running for DRP only.
Thanks to @karnanl
Thanks for the support in my issue. @andrewlan @behnam_2705new @archangel-lightworks
Kudos!!!!!!!!
@verilog_bee
If you read from the FIFO at 125M after 5 words are there but the GTH keeps on writing at higher speed, yes, you will fill it.
How are you testing this? Do you have an RX-TX loop, to make sure you send 5 and only 5 words?
Even though, some peripherals frame data, have you checked that?
What about (as a way of testing) increasing the buffer size to a few Kwords?
Cannot you handshake your GTH and pause writing the RX FIFO is near full?
We have FMC loopback card for providing the loopback to the serial output of GTH lines. And it is a continuous process of data write & read as RX_reset_done signal comes from GTH. We have managed the 5 word logic on DATA COUNT output of Xilinx's FIFO IP. As GTH write data into FIFO, wr_data_count data on the output port of FIFO get incremented & after 5 wr_data_count we enable read input of FIFO.
Yes, there is no issue with that.
we tried to increased depth, almost double the size. still facing the same issue.
No. as per design there is no such mechanism.
@verilog_bee
If you don't have a handshake between the TX FIFO and the GTH, the transceiver will not know the buffer is empty after 5 words taken and sent and will carry on sending stuff (probably the last word forever). Could this be happening?
Thanks for quick reply @archangel-lightworks
We do not have an issue at TXFIFO with the EMPTY signal. TX FIFO is working fine with clock & data. we are worried about the FULL signal asserted at RX FIFO.
Can you simulate it?
After verifying the design in the simulation we moved to hardware test. Simulation is O.K no FULL signal detected at RX.
After verifying the design in the simulation we moved to hardware test. Simulation is O.K No FULL signal detected at RX.
I request to Xilinx's support employee  &  archangel-lightworks for the kind response & suggestions on the issue.
Can you please help me on this issue. @karnanl
Hello
I think your system diagram looks like this:
I believe you are transmitting 40bit RAW data since your I/F is 40 bits. ( Please correct me , if my understanding is wrong )
My verdict:
This system will not work, since you are transmitting a raw 40 bits data using different clock domain.
There is no mechanism to absorb the clock frequency difference between domain in the system.
You should use clock correction mechanisim to absorb ppm difference between clock domain.
This features is not accesible with RAW data.
1. I believe the 125 MHz (clock A) and 125MHz (from TXUSRCLK) has a different frequency.
    # TXUSRCLK 125 MHz is faster so your RX FIFO is FULL.
2. [VB] After verifying the design in the simulation we moved to hardware test. Simulation is O.K no FULL signal detected at RX
    [LK] Your simulation seems to be okay , because ( I believe ) the 125 MHz (clock A) and 125MHz (from TXUSRCLK) has excatly the same frequency in the simulation.
3. [VB] We do not have an issue at TXFIFO with the EMPTY signal. TX FIFO is working fine with clock & data. we are worried about the FULL signal asserted at RX FIFO.
    [LK] Could you simulate your design with Clock A slightly slower than TXUSRCLK ( for example 123 MHz), and see the behavior of your TXFIFO.
           TXFIFO should say EMPTY or FULL if we have clock frequency difference between clock domain.
Leo
Hello @verilog_bee
You also put this question on the wrong board.
This is a Serial Transceiver topic.
Thanks & regards
Leo
Thanks for the quick reply.
Your understanding is absolutely right except one thing which I have corrected in the attached design. To absorb the ppm difference we put FIFO in our design.
Can you suggest any other method to absorb PPM difference in reference to GTH transceiver?
If this is not the right place for my query then please suggest me the name of Xilinx person or place where I can get support.
Hello @verilog_bee
1. "Serial Transceiver" board should be better for Transceiver related discussion.
    https://forums.xilinx.com/t5/Serial-Transceivers/bd-p/transceivers
2. Propose to use the following connectivity, with a single clock domain.
Leo
I am very glad to have such a fast response from you. @karnanl
Thanks once again to understand our situation.
We have our legacy IP core with FIFO design which I mentioned in the last reply. It is running smoothly on INTEL FPGA. At this moment, we are not able to change the whole IP core design as per your proposed clock scheme.
Let me put my query to the related forum page of the transceiver as per your suggestion.
You will have further required information for this issue If it is possible for you to help me out. OR you can simply connect the right person to me.
Thank you very much.
It seems your root problem is your 125 MHz (KCU105 kit) clock is slighly slower (e.g. PPM differences between crystals) than the GT clock causing the Rx FIFO to overflow.
How about speeding up your 125 MHz (KCU105 kit) clock to say 150Mhz? Now you can monitor the empy flag for valid data on the Rx FIFO and it will never overflow. You can either leave the Tx path as is or also use the 150Mhz clock to write data, but with flow control on the Tx FIFO full flag so you don't write to a full fifo.
Thanks for your response @andrewlan
Rest of the design is based 125MHz so It is not possible to change the clock to 150MHz.
Please share if you have other possible solution.
actually, you will not be successful until your Rx incoming clock MUST be recovered to have the same RX and TX clock.
this is the only way that I know to do to catch your desired result.
I have seen some techniques to have the same RX and TX clock, but I cannot pass the loopback test with them. consider that if you have a slight difference in your RX and TX clock( even less than 1ppm), your test will not work properly.
Hello @eschidl
Clock scheme:
Thanks to @karnanl
Kudos!!!!!!!!
