GTY Transceiver Possible Idle State
There are some properties of the input signal into the transceivers which cause them to be put into an idle-like state and I'm trying to figure out the cause.
My GTY configurations are as such:GTY settingsGTY settings
I have also attached the DRP register values for all 12 channels and 3 commons being used as .csv files. I have looked at all the registers which involve some electrical idle state and it seems none of them are the incorrect values. Perhaps the answer lies elsewhere...?
Re: GTY Transceiver Possible Idle State
hello
please can you elaborate "idle state"?
For sure 20dB loss and LPM is wrong: if you are estimating your channel IL to be 20dB, please select DFE.
Vice versa, if your channel is short and IL are low you can select LPM.
From my point of view Idle state strikes me as a major flaw.  I can only imagine it coming about if
1. The refclk is missing or coming in on the wrong pin.
2. The design is flawed and something important got optimized out.
3. You don't have a valid design.
I think you can eliminate most of these possibilities if you start with an example design and first successfully run the example design simulation.  Has this been done?
By "idle state", I mean that the signal output from the transceivers seem to be highly attenuated towards no signal at all. Resetting the transceivers solves this problem.
What changes to the transceivers would be (forced) propagated if I change the channel IL in the wizard?
The IL changes AGC inputs and a value over about 15 will invoke DFE equalization whereas lower values will use LPM.  It is hard to imagine incorrect IL putting you in IDLE state.  Make sure all of your power supplies are withing the operating limits when measured at the FPGA pins.  The voltages don't have to droop far before you get no output.
These are CML drivers so you should not be measuring the voltages open ended.  Measure on the AC coupling caps near the receiver.
For my application, the channel IL is a dynamic value during run-time. Could this cause the transceiver equalization mode to change automatically during run-time?
Would it be a good idea to set the channel IL in the wizard to be the worst-case value that could conceivably be encountered?
The equalization is adaptive so it will probably not matter.  I'm not sure we support channels with variable IL but if this is a normal temperature induced changes it would be what we are set up for.  If you expect worse case is over 15 then you may need DFE.  DFE is not for very low loss use so you should probably do some IBIS-AMI simulations and see what works best.
Observing the outputs of the individual transceivers channels, I noticed that some get stuck at either 0x000...0 or 0xFFF...F when in the trouble state.
Running a qsfp+ loopback, I noticed some of the transceiver RX data would get stuck at 0xFFFF....FF. Are there any known conditions which would cause this to happen?
I have a few additional questions:
Are you observing the "idle state" from our TX serial output or RX parallel output?
You mentioned that a reset resolves the problem. Are you only seeing the problem after power up? After reconfiguration? Does only one GT reset recovers it? Or did you have to try multiples? Does it ever go bad after reset?
I have been only looking at the RX parallel output.
Our front-end is a sensor. It seems that when the signal amplitude into the transceivers changes from one extreme to another that this idle state occurs, otherwise the transceivers operate normally.
One GT wide reset puts the transceivers back into operation, but when the signal again varies from one extreme to another (in most cases in quick succession), then this "idle" state recurs.
