Gtwizard 4K Reset Test
I am currently working on xapp 1200 xilinx for gtx transciver, but I am unable to find Gtwizard 4K Reset Test reset_fast.tcl file. Please can anybody provide me the Gtwizard 4K Reset Test  reset_fast.tcl file for xapp1200.
Re: Gtwizard 4K Reset Test
Hello @trisita92,
Can you please let me know do you have any specific reason for looking at this file? I believe In XAPP-1200 the steps are mentioned on how to generate the example design.
Naveen
Hello @trisita92,
Naveen
yes, i have reason for 4k reset test, becuse i want to verify , whether the link is working or not.
Hello @trisita92,
To verify the link you can use IBERT test.The process is the following: (you might also read the IBERT Product Guide)
1) open a new vivado design
2) create a new design
3) select your board - if it is not in the list, select your device
4) in the IP catalog pick the IBERT and add to your design
5) double clock on IBERT icon and configure the IBERT design - close the GUI
6) right click on IBERT GUI and generate the example design. This will create a new complete Vivado IBERT example design. You can close the original one
7) finally synthesize the example design and create the bit file
hope it helps
Naveen
