Implementation of USB PHY layer on GTH transceiver
Greetings,
Hi, I am a new bee at Xilinx. I want to use Ultrascale GTH transceiver for my USB 3.1 gen1 gen2 IP. is it possible to implement USB PHY on a transceiver? And does Xilinx support its configuration preset like I have seen in GTH wizard for 1g_10_25g_switchable.
Is there any reference design available for USB PHY on GTH transceiver? please guide us.
hi @verilog_bee ,
unfortunately, xilinx offically do not support the USB  , hence there is no USB IP from xilinx .
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
hi @verilog_bee ,
Chandra sekhar
