Is there a way to view the clock path in the transceiver?
Hi:
I try to find clock route like following picture:
Is there a document or tool to view the CLK path as shown above?
Re: Is there a way to view the clock path in the transceiver?
hi
Are you sure you postonh question to the correct site?
It seems like Intel document you share below.
No, I'm afraif that is not provided.  You would have to go to the clocking pages of the user guide, pages 157 and 217 for UG578 and then open an implemented design and check the settings for muxes in question.  You should have a good sense of what the muxes are set to for your design.  If you chose QPLL1 in the wizard that will mean T/RXPLLCKSEL will be 10 for instance.
