07-02-2019 11:09 AM
PROBLEM STATEMENT: In our product design portfolio we're using various variants of KINTEX-7 such as XC7K160T ; 325T ; 410T. In all cases we have concerns about field returns with QUAD115 & QUAD116 transceiver damage, isolated to the RX pairs. The symptom is an unresponsive channel with leaky or low impedance on die protection diodes. These ports have to transit to the "outside world" directly with no other transient protection or series impedance. We understand that absolute maximums on these nodes are -0.5Vp to +1.26Vp.
QUESTION: Most of our applications are short cable runs (< = 3 meters) to adjacent equipment that's hardwired (no SFP). (1) Is any other user experiencing low level but recurring field failures to the RX pair of serial transceiver?; (2) Are you also connecting directly to the outside world with no series capacitance inline? (3) Your comments of revelation please. :o)
07-03-2019 01:26 AM
Hello jay.ikerman@adtran.com
Using Transceivers without AC coupling could be very risky.
Is there any particular reason to use DC coupling on your system ?
Without AC coupling, There would be no protection against common mode currents flowing to RX pins, any ESD from “outside world” will hit RX pins directly, which may exceeding absolute maximum value stated in datasheet.
You also need to ensure that common-mode voltage on TX side is the same with RX, or else common-mode current will constantly flows during normal operation.
Thanks & regards
Leo
