04-11-2019 07:48 AM
Hi all,
I'm designing a pcb with a XCKU5P-1FFVB67, and I have 3 questions:
1) I have 4 pairs of 3G-SDI signals that I need to connect to the XCKU5P FPGA. Can I connect them to the bank 227?
2) Is the max clock rate 148.5MHz?
3) Should I connect my clock to MGTREFCLK0P_227 & MGTREFCLK0N_227; to MGTREFCLK1P_227 & MGTREFCLK1N_227; or it doesn't matter which pair?
Thanks in advance!
04-12-2019 01:59 AM
Hello Alex @alex83uk
It should be okay.
Please check PG289 and PG290 for more detailed information.
In our example design, we suggest to use 148.5 MHz for QPLL REFCLK.
Following Example design will give you a quick start for your design.
It does not matter, since you can select the REFCLK pin location from UHD-SDI GT GUI.
Hope this helps.
Leo
04-12-2019 01:59 AM
It should be okay.
Hope this helps.
Leo
