MGT Calibrated Termination Resistors - KIntex Ultrascale
I am interfacing to a DAC and the datasheet for the DAC recommends that the FPGA transmitter have a 100 ohm source resistor across the P and N pins (attachment included).
I noticed in the UG576, Ultrascale  GTH Transceiver Use Guide, it mentions that there are two calibrated termination resistors for the transmitter(attachment included).
Could these be used as recommended by the DAC datasheet? Are they controllable by the user? How do they get calibrated?
Jeff
roym
There is always termination.  It is 100 ohms after configuration.  The rcal resistor is required to be 100 ohms or very close.
We are interoperable with any compliant SGMII interface like this so there shouldn't be any trouble at all.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
roym
Yes,  I believe our GT could drive this DAC.  The calibration is done by the FPGA on configuration.  A current is driven through a known 100 ohm resistor, the RCAL resistor and measured.  Internally the resistance is calibrated to generate the same resistance.  It is not recommended to change the calibration resistance and I don't think you would need to.  If you send the part number I can look at their data sheet and try to confirm compatibility.
Thanks for your reply. I have attached the datasheet. The part is a CPU and not a DAC (sorry for the confusion). The SGMII interface that they are using starts on p.91
Thanks!
roym
There would be no issue with the termination resistance on the SGMII.  They are set up for 100 ohm lines and so are we.  I believe that is part of the ethernet specs as well.
So is there always a termination on the output of the mgt drivers? And it could be 100 ohms across p and n depending on the rcal resistor?
thanks!
roym
