OC-192 and 10G BASE-R GTX transceivers in the same QUAD
In my Kintex 7 I am currently using two GTX transceivers at OC-192 rate (9.95328) with the QPLL driven by a 311.04MHz reference clock. I am looking into modifying this into  two possible approaches:
  1. Ideally, I would like to reconfigure just one of them to support 10G BASE-R rate (10.3125). Could the NIDRU be used to pass 10G BASE-R over a OC-192 transceiver?
  2. Alternatively, I would dynamically reconfigure both transceivers from/to OC-192 (using 311M reference clock) to/from 10G BASE-R (using a 156.25M reference clock):
    • Does someone have a list of all the parameters that need to be modified?
    • Would a reset be required after reconfiguration?
    • How big of a disruption would be caused?
Thanks in advance!
hi @ezequielsasky
you have to dynamically reconfigure the transceivers and switch them between OC192 and 10G baseR.
Below is the steps list.
https://www.xilinx.com/support/answers/31968.html
You can use this flow to identify all parameters for this design.
A reset is needed after reconfiguration.
Boris
hi @ezequielsasky
Boris
Thanks Boris
Though I knew about the reconfiguration procedure, the link that you sent is helpful. I wish there was a friendlier method to compare between the attributes of two protocols, linked to a utility to load thru DRP. Would you suggest using the gt_Attributes utility?
Thanks again,
Eze
hi @ezequielsasky
yes, that utility is helpful to speed up the flow.
thanks,
Boris
