veekshitha
Pre-cursor and Post cursor
I wanted more input on pre cursor and post cursor in IBERT GTH transceievers.What is it?
How to we change the the pre and post cursor values and on what basis do we change?
roym
This is emphasis that is used to overcome intersymbol interference.  See:
https://www.xilinx.com/publications/archives/books/serialio.pdf
A good way to use it is to sweep the possible settings and use IBERT to see which setting gives the largest eye. Usually 3 or 6 dB of preemphasis will be best.
They are controlled by the TXPRECURSOR and TXPOSTCURSOR ports.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
