Observer junnit
Re: GTX Line Rate Change
Hi,I am using the DRP ports to change the TXOUT_DIV and TXOUT_DIV in GTX to change the line rate,after I make a DRP wirte to these attributes,which part of the GTX should be reset?according to the ug476 page 71,the reset will be done automatically, so should i make a reset after write these attributes?
please help me,thanks a lot,it's my bechalor final project,i have to solve it,please!
No, in your case you would need to do any resets manually.  There are ports T/RXRATE that would invoke the reset. Changing the T/RXOUT_DIV would not invoke any reset.
Observer junnit
Hi roy,thanks a lot,according to your reply,I have search the DRP reset in the ug476,but I am confused with the reset.
according to the ug476 page 85 an 76,afte change the TX rate,the TX PMA and PCS should be reset;after change the RX rate,the RX PCS should be reset,so should I assert the TXPMARESET and the RXPCSRESET after write these attributes?Can I reset the whole GTX using the soft_reset_i in the GTX reference design?it seems to reset the whole TX RX datapath and the QPLL(I am using the QPLL for my project),thanks a lot!
