03-22-2019 02:25 PM - edited 03-22-2019 02:29 PM
Hi all,
I am looking to use transceivers with quads that exist on multiple chips/boards but that also require a shared clock between them all. What is the best way to do this? Is this possible with two development boards (ex. multiple vcu118s connected somehow to share transceivers clocks)?
03-25-2019 12:01 AM
hi @bfung
VCU118 or other Xilinx eval boards commonly have a SMA reference clock input.
You can use a clock generator with two output ports and connected them to two VCU118s with the SMA cables.
The pin on VCU118 is below.
MGTREFCLK0 - MGT226_CLK0_P/N (SMA J31 P, J30 N)
A single clock ouput splitted into two is not recommanded. i.e., we need point to point connection for ref clocks.
Boris
