Ultrascale+ how to connect two different transceiver of same quad with two different reference clock
I am trying to connect the two different clock one with 125MHz and other with 148.5MHz for the SFP+ and the SDI respectively.
I am not able to do that , as it is connecting clock to the QPLL0 , and all the transceiver will be connected to the either clock_0 or clock_1 of that GTH bank or corresponding bank
So is there any alternative ?
Can I make changes to this while generating the example design for it?
Is there any method to enable the OPLL1 and also QPLL0 at the same time so i can connect the two different clock while generation of the example design or by the verilog code ?
Akshay
AKSHAY
borisq
hi akshay.bhat@iwavesystems
- example design may need some manual edit to suppor that.
GT Wizard GUI cannot fully support that, but you can follow below example as start point.
https://www.xilinx.com/support/answers/65228.html
Boris
