08-20-2019 07:45 AM
VCU128 Board, Vivado 2019.1
I'm using two quads: X0Y3 and X0Y1. The two transceiver RX busses are split between the two quads as follows (snapshots below):
They share the same mgtrefclk, which is MGTREFCLK0 of X0Y3. I followed the guidelines shown in Figure 3-10 of PG182 as follows:
I get an unroutable placement error (below). It says I have the option of overriding, so I'd like to know if that's a reasonable thing to do given my design.
Thanks very much for any help.
transB and transC:
ERROR:
[Place 30-738] Unroutable Placement! A GTYE_COMMON / GTYE_CHANNEL clock component pair is not placed in a routable site pair. The GTYE_COMMON component can use the dedicated path between the GTYE_COMMON and the GTYE_CHANNEL if both are placed in the same clock region.If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
< set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_common.gen_common_container[3].gen_enabled_common.gtye4_common_wrapper_inst/common_inst/qpll0outclk_out[0]] >
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_common.gen_common_container[3].gen_enabled_common.gtye4_common_wrapper_inst/common_inst/gtye4_common_gen.GTYE4_COMMON_PRIM_INST (GTYE4_COMMON.QPLL0OUTCLK) is provisionally placed by clockplacer on GTYE4_COMMON_X0Y3 (in SLR 0)
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[0].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y12 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[0].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y13 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[1].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y14 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[2].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y15 (in SLR 0)
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[1].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[1].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y6 (in SLR 0)
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[1].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[2].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y7 (in SLR 0)
The above error could possibly be related to other connected instances. Following is a list of
all the related clock rules and their respective instances.
Clock Rule: rule_bufgsync_bufg_withGTDriver
Status: PASS
Rule Description: A BUFG_GT_SYNC driving a BUFG_GT must be placed in the same clock region of the device
as the BUFG_GT
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[1].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/BUFG_GT_SYNC (BUFG_GT_SYNC.CESYNC) is provisionally placed by clockplacer on BUFG_GT_SYNC_X0Y26 (in SLR 0)
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/gen_gtwiz_userclk_rx_main.bufg_gt_usrclk_inst (BUFG_GT.CE) is provisionally placed by clockplacer on BUFG_GT_X0Y26 (in SLR 0)
Clock Rule: rule_gt_bufggt
Status: PASS
Rule Description: A GT driving a BUFG_GT must be placed in the same clock region of the device as the
BUFG
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[1].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[2].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.RXOUTCLK) is locked to GTYE4_CHANNEL_X0Y7 (in SLR 0)
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/gen_gtwiz_userclk_rx_main.bufg_gt_usrclk_inst (BUFG_GT.I) is provisionally placed by clockplacer on BUFG_GT_X0Y26 (in SLR 0)
Clock Rule: rule_gtychannel_bufgsync_rx
Status: PASS
Rule Description: A GTYChannel drives a BUFG_GT_SYNC pin must both be in the same clock region and
both have to be in specific sites.
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[1].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/BUFG_GT_SYNC (BUFG_GT_SYNC.CLK) is provisionally placed by clockplacer on BUFG_GT_SYNC_X0Y26 (in SLR 0)
Clock Rule: rule_bufggt_pll
Status: PASS
Rule Description: A BUFG_GT driving PLL must be in the same clock region row
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/gen_gtwiz_userclk_rx_main.bufg_gt_usrclk_inst (BUFG_GT.O) is provisionally placed by clockplacer on BUFG_GT_X0Y26 (in SLR 0)
Clock Rule: rule_gtycommon_gtychannel
Status: PASS
Rule Description: A GTYCommon driving a GTYChannel must both be in the same clock region
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_common.gen_common_container[3].gen_enabled_common.gtye4_common_wrapper_inst/common_inst/gtye4_common_gen.GTYE4_COMMON_PRIM_INST (GTYE4_COMMON.QPLL1OUTCLK) is provisionally placed by clockplacer on GTYE4_COMMON_X0Y3 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[0].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL1CLK) is locked to GTYE4_CHANNEL_X0Y13 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[1].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL1CLK) is locked to GTYE4_CHANNEL_X0Y14 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[2].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL1CLK) is locked to GTYE4_CHANNEL_X0Y15 (in SLR 0)
Clock Rule: rule_bufds_gtycommon_intelligent_pin
Status: PASS
Rule Description: A BUFDS driving a GTYCommon must both be placed in the same or adjacent two clock
regions (top/bottom)
ibuf_mgtclkc (IBUFDS_GTE4.O) is locked to GTYE4_COMMON_X0Y3 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_common.gen_common_container[1].gen_enabled_common.gtye4_common_wrapper_inst/common_inst/gtye4_common_gen.GTYE4_COMMON_PRIM_INST (GTYE4_COMMON.GTREFCLK00) is provisionally placed by clockplacer on GTYE4_COMMON_X0Y1 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_common.gen_common_container[3].gen_enabled_common.gtye4_common_wrapper_inst/common_inst/gtye4_common_gen.GTYE4_COMMON_PRIM_INST (GTYE4_COMMON.GTREFCLK00) is provisionally placed by clockplacer on GTYE4_COMMON_X0Y3 (in SLR 0)
Status: PASS
BUFG
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[0].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.RXOUTCLK) is locked to GTYE4_CHANNEL_X0Y13 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/gen_gtwiz_userclk_rx_main.bufg_gt_usrclk_inst (BUFG_GT.I) is provisionally placed by clockplacer on BUFG_GT_X0Y77 (in SLR 0)
Status: PASS
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/BUFG_GT_SYNC (BUFG_GT_SYNC.CLK) is provisionally placed by clockplacer on BUFG_GT_SYNC_X0Y49 (in SLR 0)
Status: PASS
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_common.gen_common_container[1].gen_enabled_common.gtye4_common_wrapper_inst/common_inst/gtye4_common_gen.GTYE4_COMMON_PRIM_INST (GTYE4_COMMON.QPLL0OUTCLK) is provisionally placed by clockplacer on GTYE4_COMMON_X0Y1 (in SLR 0)
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[1].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[0].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y5 (in SLR 0)
adc_transB/inst/gen_gtwizard_gtye4_top.adc_gty_B_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[1].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/gtye4_channel_gen.gen_gtye4_channel_inst[0].GTYE4_CHANNEL_PRIM_INST (GTYE4_CHANNEL.QPLL0CLK) is locked to GTYE4_CHANNEL_X0Y4 (in SLR 0)
Status: PASS
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/gen_gtwiz_userclk_rx_main.bufg_gt_usrclk_inst (BUFG_GT.O) is provisionally placed by clockplacer on BUFG_GT_X0Y77 (in SLR 0)
Status: PASS
as the BUFG_GT
adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_channel_container[3].gen_enabled_channel.gtye4_channel_wrapper_inst/channel_inst/BUFG_GT_SYNC (BUFG_GT_SYNC.CESYNC) is provisionally placed by clockplacer on BUFG_GT_SYNC_X0Y49 (in SLR 0)
and adc_transC/inst/gen_gtwizard_gtye4_top.adc_gty_C_gtwizard_gtye4_inst/gen_gtwizard_gtye4.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/gen_gtwiz_userclk_rx_main.bufg_gt_usrclk_inst (BUFG_GT.CE) is provisionally placed by clockplacer on BUFG_GT_X0Y77 (in SLR 0)
08-27-2019 03:46 PM
08-27-2019 03:46 PM
05-07-2020 12:04 PM
It's been awhile, but I finally got back to this. Applying the technique in AR65228 does work. I modified the transceivers for "B" to use QPLL0 and enable QPLL1, and "C" to use QPLL1 and enable QPLL0. In the common wrapper, I had two common logic blocks, one for X0Y1 and one for X0Y2, and interleaved them together as follows:
qpll0clk <= qpll0outclk_x0y3(0) & qpll0outclk_x0y1(0) & qpll0outclk_x0y1(0) & qpll0outclk_x0y1(0);
qpll0refclk <= qpll0outrefclk_x0y3(0) & qpll0outrefclk_x0y1(0) & qpll0outrefclk_x0y1(0) & qpll0outrefclk_x0y1(0);
qpll0lock <= qpll0lock_x0y3(0) & qpll0lock_x0y1(0);
qpll1clk <= qpll1outclk_x0y3(0) & qpll1outclk_x0y3(0) & qpll1outclk_x0y3(0) & qpll1outclk_x0y1(0);
qpll1refclk <= qpll1outrefclk_x0y3(0) & qpll1outrefclk_x0y3(0) & qpll1outrefclk_x0y3(0) & qpll1outrefclk_x0y1(0);
qpll1lock <= qpll1lock_x0y3(0) & qpll1lock_x0y1(0);
The QPLL0 signals hooked in to transceiver B, with the QPLL1 signals of B zeroed out. The QPLL1 went to C, with the QPLL0 signals zeroed out.
I'd missed this information in the AR the first time, so I'm calling it out here for anyone reviewing this for an answer.
Finally, thanks to jhua for pointing me to the right AR.
