Using RXOUTCLK as Tx MGTREFCLK
Target FPGA : Zynq Ultrascale+
I would like to pass RXOUTCLK to an external clock cleaner, then use the output as MGTREFCLK for TX.  Rx is 12Gbps, Tx is 12Gbps.  The received data is processed and re-transmitted using the aforementioned MGT TX.
I have FIFOs in path to handle momentary jitter between RX data rate and TX data rate.
But I am concerned about long term clock slip between RX clk and cleaned TX clk, which will cause data loss.
My question is, will the cleaned clock be able to maintain the same frequency as RX clock?
回复: Using RXOUTCLK as Tx MGTREFCLK
hi wtneo@leica
is it CPRI slave design? or something else.
if the incoming data remain the same frequency, the recover clock will maintain, and thereby the cleaned clock will maintain.
we have some boards with jitter attenuator like SI5328. you can do some evaluation.
Boris
hi wtneo@leica
Boris
Hi Boris,
  It is not CPRI, but the RX link will be always connected and constant data rate.
Neo
