failed to run xapp1240 in kcu105
I want to capture STM-1 data by SFP of the kcu105 board, I have read xapp1240 (NIDRU) and downloaded all design sources, As you know this xapp run 2 rate data transfer (1 GE and STM 1 ) I have commented the process related to 1 GE prbs checker and generator and only use two-channel with the same rate GT transceiver, my parameters are:
G1 = G2 = 8
G1_P=16
center_f=  5343626510
my board is kcu105
STM-1 signal is conning into my board (rate of STM 1 is 155.52) and my reference clock is 125 Mhz
I fellow the xapp but I cannot achieve my desired result, my desire result is passing the loopback test which has mentioned in xapp the counter that related to prbs error is always going up until reach FFFF_FFFF.
is there any other issue that I should consider to achieve the correct output?
Re: failed to run xapp1240 in kcu105
your setup is correct (you wrote the CENTER_F in decimal notation)
Is the simulation working?
is the incoming STM-1 signal a PRBS pattern? is the same PRBS type selected at receiver side PRBS checker?
Thanks for your response.
I have tested it and your response is so helpful for me.CENTER_F was not determining good.I changed it and now I have one side transiever in rate of STM-1
