Visitor ydelican123
gtp transceiver SPARTAN 6
Can we connect two FPGAs using MGTTXN0_123(TX-),MGTTXP0_123(TX+) pins of FPGA1 and MGTRXN0_123(RX-),MGTRXP0_123(RX+) pins of FPGA2 without using MGTREFCLK0N_123 and MGTREFCLK0P_123 pins. I am using Spartan 6 FPGA, XC6SLX150T.
Re: gtp transceiver SPARTAN 6
Could you clarify your question
What is your data rate?
Do you want to run GT without any clock? Or you dont want to use specific pin as a clock source?
Visitor ydelican123
I have not decided about data rate. I want to test these signals now (interconnection test). But I am not sure how to test these signals.
Have you seen locked signal of clock? (Cpll or qpll)
What data do you send on the link?
Could you recieve or monitor data with ila?(chipscope)
You can't run GT core without any Refclk given. To establish a communication between two boards you need to setup the GTPs and then be careful about the data encoding to lock the plls.
Scholar watari
Hi @ydelican123
If you imprement CDR function, you don't need any external differential clock signals.
