Anonymous
Not applicable
A question about FPGA's power characteristics
Theoretically, power consumption of a semiconductor device is expected to be proportional to the square of the clock frequency. However, FPGA chips has a linear power vs frequency characteristics. I wonder what might be the reason behind this? Does anyone have an explanation for why power consumption of FPGA chips increases linearly with clock frequency?
Best,
A. Caner Yüzügüler
athandr
Where did you read about the linearity of the power with clock frequency.
The power consumption in an FPGA depends on many factors as the logic inside the FPGA is not fixed.
Based on the different component utilizations and the clock used for that, the power consumption increases. You can check the XPE spreadsheet and input values based on your expected device utilization to check the pwoer consumed - http://www.xilinx.com/products/design_tools/logic_design/xpe.htm
Anirudh
Anonymous
Not applicable
I have tested it personally. I only changed clock frequency of my design (output of PLL) without modifying the design while resource usage, toggle rates etc. remain unchanged and measured the current supplied from Vccint. When I plot 'power vs frequency' graph over 5 MHz and 500MHz , I observed that it is exactly linear. Besides, XPE also indicates a linear increase on power when the clock frequency is increased.
My question is, a usual silicon transistor's power consumption is directly proportional to the square of the clock frequency. But for a Xilinx FPGA chip, it is linearly increasing with clock frequency. Is it possible Xilinx uses a different technology with such a power characteristics?
Best,
A. Caner Yüzügüler
mcgett
You need to go back and check your textbooks, but this wrong.   Dynamic power is approximately = C*V^2*F
gszakacs
Professor
Professor
Just to beat this dead horse one more time, the power is linear with frequency because power is energy per unit time, and the energy to switch a capacitance on or off once is fixed for a given voltage.  Twice the frequency will switch the capacitor twice as many times in a second, or twice the energy per second, hence twice (not 4 times) the power.
-- Gabor
