mjholmes99
Erasing an EEPROM
When Impact erases an EEPROM (an XCF32, for example), does it just set things back to all 1, or can it be made to write a random pattern first?
barriet
If you need a specific pattern for a specific usage (e.g. sanitization), you could alway do this manually, e.g.
Open iMPACT, open a boundary scan window, and initialize the chain with the cable connected and board powered on
erase the PROM
perform a Readback operation on the PROM, specify a target MCS file
convert the read mcs to .hex: promgen -r <filename>.mcs -p hex -o <filename>.hex
modify this hex file with the desired data/pattern with a text editor, making sure to keep the same number of characters
convert the new hex back to mcs: promgen -r <filename>.hex -p mcs -o <filename>.mcs
use iMPACT to program the new .mcs
Of course, don't expect th FPGA to successfully configure this way. Might be a good idea change the FPGA's MODE M[2:0]  pins to something like JTAG or a slave mode instead of a master mode. to avoid  actually trying to configure with this pattern later...
Cheers,
bt
gszakacs
Instructor
Instructor
The XCF series are Flash, which is electrically erasable, but not "EEPROM" in the usual sense of
byte re-writable devices.  It gets erased to all 1's because there is no other "erased" state of the
flash.  You can request that Impact fill unused locations with a value other than FF (all ones), but
it can't do that during the erase, because any other value would not leave the flash writable.
-- Gabor
-- Gabor
barriet
erase the PROM
Cheers,
bt
mjholmes99
More steps than I'd hoped for, but I can build a sanitization procedure from this. Thanks!
Yeah, I use "EEPROM" purely out of bad habit. I still remember using UV erasers and putting stickers over the little windows. I'm old. :(
rcingham
I remember putting a windowed EPROM in the programmer backwards and having it light up!
"If it don't work in simulation, it won't work on the board."
gszakacs
Instructor
Instructor
Back in 1979 I remember that we were just starting to build products with microprocessors
instead of just TTL.  We had a new programming guy (it wasn't really "software" in those days)
who had the same experience.  He found it so amusing that he pulled out another EPROM
and showed me.  At the time the 2716 EPROM cost us about $35.  As an aside, the EPROM
and the programmer were both made by Intel.  Apparently adding circuitry to sense incorrect
insertion would be bad for their bottom line...
-- Gabor
-- Gabor
