Visitor sabdullah
2014.3 VIVADO Simulator error [USF-XSim-62]
I am trying to simulate my project, but I keep receiving an error:
ERROR: [USF-XSim-62] 'compile' step failed with error(s). Please check the Tcl console ouput or ' ' file for more information.
I tried looking at other threads and tried changing output reg A, but it didn't make a difference. Thanks in advance!
`timescale 1ns / 1ps
module SYS(c, Data, clk, B, Cout, A);
   // paramter n=4;
   input [4:0] c;
   input [3:0] Data;
   input clk;
   input [3:0] B;
   output Cout;
   output reg [3:0] A;
    reg [3:0] bus  ;
    wire [3:0]PAout;
    wire [3:0] gate;
    initial A=0;
    //register A
    always @(posedge clk)
    begin
    if (c[0])
        A <= 4'b0000;
    else if (c[1])
        A <= A + 1;
    else if (c[2])
        A <= bus;
    end
    //mux
    always @(c[3] or Data or PAout)
    begin
    if (c[3])
        bus = Data;
    else
        bus = PAout;
    end
    begin
    assign gate = B ^ c[4];
    end
    //PA
    always @( A or gate or c[4])
    begin
    if (c[4])
        A = A - gate;
    else
        A = A + gate;
    end
endmodule
 TESTBENCH:
module SIMSYS1();
   reg clk;
   reg [4:0] c;
   reg [3:0] Data, B;
   wire [3:0] A;
SYS x(c, Data, clk, B, Cout, A);
   initial
   begin
    clk = 0, Data = 0, B = 0, c = 0;
    forever #5 clk = ~clk;
        #4  c[0] = 1; c[1] = 0; c[2] = 0; // reset
        #10  c[0] = 0; c[1] = 0; c[2] = 1; C[3] = 0; Data = 6; //Load
        #10 c[0] = 0; c[1] = 1; c[2] = 0; // increment
        #10  c[0] = 0; c[1] = 0; c[2] = 1; c[3] = 1; c[4] = 0; B = 6; end  // Adding A + 6
        #10 begin c[0] = 0; c[1] = 0; c[2] = 1; c[3] = 1; c[4] = 1; B = 5; end  // Subtracting A - 5
        #10 $finish;
   end
endmodule
Re: 2014.3 VIVADO Simulator error [USF-XSim-62]
It seems there are some syntax errors in your test bench.With this tets bench and module I am able to run the simulation.
module SIMSYS1();
reg clk;
reg [4:0] c;
reg [3:0] Data, B;
wire [3:0] A;
initial
begin
clk = 0;Data = 0;B = 0;c = 0;
#10 c[0] = 0; c[1] = 0; c[2] = 1;c[3] = 0; Data = 6; //Load
#10 c[0] = 0; c[1] = 0; c[2] = 1; c[3] = 1; c[4] = 0; B = 6; // Adding A + 6
#10 $finish;
end
endmodule
 Top module:
   // paramter n=4;
   input [4:0] c;
   input [3:0] Data;
   input clk;
   input [3:0] B;
   output Cout;
   output reg [3:0] A;
    reg [3:0] bus  ;
    wire [3:0]PAout;
    reg [3:0] gate;
    initial A=0;
    //register A
    begin
    if (c[0])
        A <= 4'b0000;
    else if (c[1])
        A <= A + 1;
    else if (c[2])
        A <= bus;
    end
    //mux
    begin
    if (c[3])
        bus = Data;
    else
        bus = PAout;
    end
    begin
    end
    //PA
    begin
    if (c[4])
        A = A - gate;
    else
        A = A + gate;
    end
endmodule
Visitor sabdullah
It is actually Vivado 2014.4
If you want to use gate inside the always block it should be declared as reg.
Declare gate as reg then it should work.
    begin
    end
And also,
I would suggest you to refer verilog LRM or any text book to check the usage of those constructs.
Many resources are availble on web and you can refer to the attached LRM also.
Visitor sabdullah
Hi, I followed your suggestion, but unfortunately I am receiving the same error.
   // paramter n=4;
   input [4:0] c;
   input [3:0] Data;
   input clk;
   input [3:0] B;
   output Cout;
   output reg [3:0] A;
    reg [3:0] bus  ;
    wire [3:0]PAout;
    reg [3:0] gate;
    initial A=0;
    //register A
    begin
    if (c[0])
        A <= 4'b0000;
    else if (c[1])
        A <= A + 1;
    else if (c[2])
        A <= bus;
    end
    //mux
    begin
    if (c[3])
        bus = Data;
    else
        bus = PAout;
    end
    begin
    gate = B ^ c[4];
    end
    //PA
    begin
    if (c[4])
        A = A - gate;
    else
        A = A + gate;
    end
endmodule
Refer to the tcl console and see what is the exact error that you are seeing. The message that you posted just says that there is an error.
Thanks,Vijay
module SIMSYS1();
reg clk;
reg [4:0] c;
reg [3:0] Data, B;
wire [3:0] A;
initial
begin
#10 $finish;
end
endmodule
 Top module:
   // paramter n=4;
   input [4:0] c;
   input [3:0] Data;
   input clk;
   input [3:0] B;
   output Cout;
   output reg [3:0] A;
    reg [3:0] bus  ;
    wire [3:0]PAout;
    reg [3:0] gate;
    initial A=0;
    //register A
    begin
    if (c[0])
        A <= 4'b0000;
    else if (c[1])
        A <= A + 1;
    else if (c[2])
        A <= bus;
    end
    //mux
    begin
    if (c[3])
        bus = Data;
    else
        bus = PAout;
    end
    begin
    end
    //PA
    begin
    if (c[4])
        A = A - gate;
    else
        A = A + gate;
    end
endmodule
Visitor sabdullah
I noticed that you changed the commas in the test bench to semi-colons and I had also forgotten to omit "end" from one of the lines.. I copy and pasted the code you gave me and ran the simulation, but I am still receiving the same error.
ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Please see the Tcl Console or the Messages for details.
ERROR: [USF-XSim-62] 'simulate' step failed with errors. Please check the Tcl console or log files for more information.
Visitor sabdullah
OK, it works now after I fixed the license issue. Thank you!
Newbie real
Could you tell me how to fix the license issue ? Thank you !!
while the following is my code ,one of my partner had help me try the simulation behaviour on his computer and it succeed! what's wrong on my computer . anyone can tell me ?
error:
  • [USF-XSim 62] 'compile' step failed with error(s) while executing 'D:/vivadoWS/project_1/project_1.sim/sim_1/behav/compile.bat' script. Please check that the file has the correct 'read/write/execute' permissions and the Tcl console output for any other possible errors or warnings.
module projecttow(out, a, b, sl);
@pulim wrote:
module SIMSYS1();
reg clk;
reg [4:0] c;
reg [3:0] Data, B;
wire [3:0] A;
initial
begin
#10 $finish;
end
endmodule
 Top module:
   // paramter n=4;
   input [4:0] c;
   input [3:0] Data;
   input clk;
   input [3:0] B;
   output Cout;
   output reg [3:0] A;
    reg [3:0] bus  ;
    wire [3:0]PAout;
    reg [3:0] gate;
    initial A=0;
    //register A
    begin
    if (c[0])
        A <= 4'b0000;
    else if (c[1])
        A <= A + 1;
    else if (c[2])
        A <= bus;
    end
    //mux
    begin
    if (c[3])
        bus = Data;
    else
        bus = PAout;
    end
    begin
    end
    //PA
    begin
    if (c[4])
        A = A - gate;
    else
        A = A + gate;
    end
endmodule
@pulim wrote:
module SIMSYS1();
reg clk;
reg [4:0] c;
reg [3:0] Data, B;
wire [3:0] A;
initial
begin
#10 $finish;
end
endmodule
 Top module:
   // paramter n=4;
   input [4:0] c;
   input [3:0] Data;
   input clk;
   input [3:0] B;
   output Cout;
   output reg [3:0] A;
    reg [3:0] bus  ;
    wire [3:0]PAout;
    reg [3:0] gate;
    initial A=0;
    //register A
    begin
    if (c[0])
        A <= 4'b0000;
    else if (c[1])
        A <= A + 1;
    else if (c[2])
        A <= bus;
    end
    //mux
    begin
    if (c[3])
        bus = Data;
    else
        bus = PAout;
    end
    begin
    end
    //PA
    begin
    if (c[4])
        A = A - gate;
    else
        A = A + gate;
    end
endmodule
input a, b, sl;
output out;
wire nsl, sela, selb;
assign nsl = ~sl;
assign sela = a & nsl;
assign selb = b & sl;
assign out = sela | selb;
endmodule
