Voyager
Voyager
2014.4.1 stuck at Executing elaborate step ...
I have relative small design, about 3% of Kintex7-325t.
While implementation from scratch takes about 1.5hrs. Simulation seems to stuck at "Executing elaborate step..."
elaborate.log shows:
Vivado Simulator 2014.4
Copyright 1986-1999, 2001-2014 Xilinx, Inc. All Rights Reserved.
Running: C:/Xilinx/Vivado/2014.4/bin/unwrapped/win64.o/xelab.exe -wto 1cd677141e17408cacabe67d79cb63de --debug typical --relax -L fifo_generator_v12_0 -L xil_defaultlib -L blk_mem_gen_v8_2 -L xbip_utils_v3_0 -L xbip_pipe_v3_0 -L xbip_bram18k_v3_0 -L mult_gen_v12_0 -L unisims_ver -L unimacro_ver -L secureip --snapshot tb_Top_behav xil_defaultlib.tb_Top xil_defaultlib.glbl -log elaborate.log
Multi-threading is on. Using 6 slave threads.
Starting static elaboration
Completed static elaboration
Starting simulation data flow analysis
Completed simulation data flow analysis
I have no idea, what's going on. Tool setup seems to fine, since I can simulate dummy testing design.
Please advise how to troubleshoot this.
Re: 2014.4.1 stuck at Executing elaborate step ...
Try disabling multi threading also check with 2015.1
Thanks,Vijay
Can you post a testcase here?
Also, how much time is it waiting in that stage?
Debraj
Voyager
Voyager
Thanks a lot for looking into my issue.
I am quite certain, my design source confused tool somehow; My project is messy uncompleted code base with a lot of critical warnings. But it implemented with some timing failure.
I was expecting just to get behavior simulation. I also reduced testbench to just one process of $display and clock generation.
I've tried 2015.1 same stuck. I was expecting to be able to pull a bit more info or trouble shooting log. Any verbose log?
But on the other side, simulation kicks off quickly in ModelSim.
Will keep investigating and share my finding here.
In XSIM turn on the verbose setting for elaboration:
Debraj
Debrajr,
    I came across this thread when investigating what I thought was an excessive elab time.  I have what I think is a simple design and I am getting unusually long elab times.  I turned on verbose in the sim elab, and I get more messages, but there are no messages coming out when processing is "stalled".  I see 2 cores running during this time so elab is definitely running.  The project eventually simulates OK.  I have a much larger project that also has a very long elab time.  What were we supposed to see when you suggested turning on verbose messages?
Windows 7/64 viv 2015.2, vhdl
Ed
Bumping thread.
I am seeing the same issue. All the verbose messages show me are the generics I'm passing into each file from the top level test-bench. Elaborating for days.
CentOS7 Vivado 2015.4 Design Ed.
@gutel
Can you give it a try with latest version of Vivado i.e. 2017.3?
Nupur
I don't know if it is related, but in case it is useful in the investigation of this issue, I am seeing exceedingly long elaboration times with Cadence ncelab when I use both the UNISIM_VER library and our own tech library for a piece of gate-level verilog in the design.
If I leave out one small file from the design (about 100 lines gate level verilog), elaboration takes less than 4 minutes, equally if I leave out the Xilinx PCIe IP and include the gate level it is about the same.
With the full design present, it takes over an hour to elaborate (but does eventually simulate correctly).
With the full design when I run ncelab on its own with "-libverbose" option, I see ncelab is stuck churning on looking for the PCIE_2_1 core, which it eventually finds in UNISIMS_VER.
