flowe
2017.1 - java.lang.reflect.InvocationTargetException
we run into a problem starting build in simulator in new Vivado. It might be only one machine, cause it work's on another one.
Anyway, if we try to start a simulation a "Vivado Internal Exception" window pops up saying "Vivado is in an unstable state".
The error appears also with the IP Core Example Projects.
[Vivado 12-106] *** Exception: java.lang.reflect.InvocationTargetException (See /home/florian.weiss/vivado_pid4336.debug)
[Vivado 12-106] *** Exception: java.lang.NullPointerException (See /home/florian.weiss/vivado_pid4336.debug)
We tried to reinstall Vivado and updated to the newest JDK. On same machine Vivado 2016.4 works fine.
Help would be appreciated.
svenn
I see the same failure in creating a simulation in 2017.1 on a win10 and a win 8.1 machine.
Both running simulations in 2016.3.
svenn
@xilinx: I am wondering if this issue has to do with signal <= 'H' assignment in vhdl. In all testbenches where this error happens, I have been trying to simulate i2c where the wires are Z when data actually is high, and then the 'H' assignment pulls the wire high.
amaccre
Hi flowe,
Have a look at the following Answer Record, it may help.
There is an issue with Java on some Linux machines in 2017.1, this has been fixed in 2017.2
https://www.xilinx.com/support/answers/69088.html
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
dpaul24
Reopening this thread, as I am seeing this exception in Viv 2017.1 (64-bit) on Windows 7.
I tried the solution as told above, to re-name the protobuf-java-3.1.0.jar file. But it didn't work.
So now I will install the 2017.2, open my project with the new Vivado and see what happens.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dpaul24
Update to my above post.
I have once run my project with Vivado 2017.2 and while opening waveforms containing Xs or Zs, I don't see the Java Exception error message.
rappysaha
The workaround solve my similar problem in Vivado 2020.2
Thank you
