AXI VIP simulation error
vivado printed information:
5825000 : testbench.DUT.hp_axi3_vip_slv.inst.genblk1.PC.REP  : BIT(     37) : ERROR : AXI_ERRM_ARADDR_BOUNDARY: Aburst must not cross a 4kbyte boundary.Spec: section A3.4.1
13235000 : testbench.DUT.gp_axi3_vip_slv.inst.genblk1.PC.REP  : BIT(     37) : ERROR : AXI_ERRM_ARADDR_BOUNDARY: Aburst must not cross a 4kbyte boundary.Spec: section A3.4.1
FATAL_ERROR:Vivado Simulator kernel has discovered an exceptional condition from which it cannot recover. Process will ternimate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Time: 3917585 ns Iteration: 2 Process: /axi_vip_pkg/axi_slv_wr_driver(C_AXI_PROTOCOL=1,C_AXI_WID_WIDTH=1,C_AXI_RID_WIDTH=1,C_AXI_HAS_QOS=0):File:/wrk/2017.4/nightly/2017_12_15_2086221/prep/rdi/vivado/data/xilinx_vip/hdl/axi_vip_pkg.sv
HDL Line:/wrk/2017.4/nightly/2017_12_15_2086221/prep/rdi/vivado/data/xilinx_vip/hdl/axi_vip_pkg.sv :1474
WARNING:[Simulator 45-29] Cannot open source file /wrk/2017.4/nightly/2017_12_15_2086221/prep/rdi/vivado/data/xilinx_vip/hdl/axi_vip_pkg.sv:file does not exist.
Re: AXI VIP simulation error
Hi @greenbirdflybiubiu
Crossing a 4K boundary is forbidden by the AXI spec. You might want to make sure you are solving this first on your master then it can solve the exceptional condition.
Crossing a 4K boundary mean that you have a burst starting before a boundary and ending after.
The boundaries are
xxxxxFFF to xxxxx000
Florent
回复: AXI VIP simulation error
Hi @florentw
Thank you so much for your reply!
I hanve solved the 4KB boundary problem ,but the fatal error still exists.
Time: 890755 ns Iteration: 2 Process: /axi_vip_pkg/axi_slv_wr_driver(C_AXI_PROTOCOL=1,C_AXI_WDATA_WIDTH=64,C_AXI_RDATA_WIDTH=64,C_AXI_WID_WIDTH=1,C_AXI_RID_WIDTH=1,C_AXI_HAS_QOS=0)::get_rd_reactive
HDL Line:/wrk/2017.4/nightly/2017_12_15_2086221/prep/rdi/vivado/data/xilinx_vip/hdl/axi_vip_pkg.sv :14299
HI @greenbirdflybiubiu
Can you share a test case?
What vivado version are you using?
What OS are you working on ?
Florent
Hi @florentw
I am sorry, I could not share the case due to permission issues.
Vivado 2017.4
OS: win10
I used to AXI_VIP in one case, one for GP port (data width:32bit), another for HP port(data width:64bit).
Could you try with a newer version of vivado?
Florent
OK,I will try it.
