pgigliotti_usac
Accessing lower level signals in Vivado simulator
I have seen the literature, but cannot see the reason for the error. I am using 2020.1
I have the following code in my to level test bench, but I get a syntax error complaint near the "<"
constant FRAM_depth :integer := 2048;
type Fram_Mem_2048x8 is array (0 to (FRAM_depth -1)) of std_logic_vector(7 downto 0);
alias FRAM_memory_alias is <<signal Inst_VMUX_Top.INST_ADN4604.FRAM_Memory : Fram_Mem_2048x8>>;
I have also tried putting a dot in the path name, but still get the same error.
alias FRAM_memory_alias is <<signal .Inst_VMUX_Top.INST_ADN4604.FRAM_Memory : Fram_Mem_2048x8>>;
As you can surmise, I am trying to access a lower level memory array.
pgigliotti_usac
I ended up going into the file properties and selecting VHDL-2008 as the file type. (from UG 901) It seems there is not a way to set all files to VHDL-2008 and if doing so is a problem?
Setting up Vivado to use VHDL-2008
There are several ways to run VHDL-2008 files with Vivado.
You can go to the Source File Properties window, and set Type: VHDL 2008 from the drop-down of available file types. The Vivado tool then sets that the file type to VHDL-2008.
You can also set files to VHDL-2008 with the set_property command in the Tcl Console. The syntax is as follows:
set_property FILE_TYPE {VHDL 2008} [get_files .vhd]
Finally, in the Non-Project or Tcl flow, the command for reading in VHDL has VHDL-2008 is as follows:
read_vhdl -vhdl2008 .vhd
If you want to read in more than one file, you can either use multiple read_vhdl commands or multiple files with one command, as follows:
read_vhdl -vhdl2008 {a.vhd b.vhd c.vhd}
pgigliotti_usac
richardhead
To set all files to 2008, use
set_property FILE_TYPE {VHDL 2008} [get_files *.vhd]
