Are these two codes supposed to be the same?
I wonder if there is difference between
always @ (posedge clk) begin
x <= 0;
if (condition) x <= 1;
end
and
always @ (posedge clk) x <= condition;
Their waveforms look the same, but they act differently when it comes to waiting for these signals in a testbench.
I made a very simple and clear test.
My DUT code:
module proba_mt( input clk,
                 output logic X=0,
                 output logic Y=0
timeunit 1ns;
timeprecision 1ps;
logic [3:0] cnt = 4'b0000; always @ (posedge clk) cnt <= cnt + 1; // cnt[3] will be the 'condition' always @ (posedge clk) X <= cnt[3]; // CASE 1 always @ (posedge clk) begin // CASE 2 Y <= 0; if (cnt[3]) Y <= 1; end endmodule
and my testbench:
module tb_proba();
timeunit 1ns;
timeprecision 1ps;
logic clk = 1;
always #5 clk++;
logic X;
logic Y;
logic sx=0;
logic sy=0;
proba_mt DUT ( .clk,  .X,  .Y );
always begin
    @(posedge X)  sx = 1;
    @(negedge X)  sx = 0;
end
always begin                     // EXACTLY THE SAME AS WITH X
    @(posedge Y)  sy = 1;
    @(negedge Y)  sy = 0;
end
endmodule
And this is what I get:
Any comments welcome.
Thank you.
Miklos
Re: Are these two codes supposed to be the same?
Here is The Solution ! :)
If X has zero-width glitches, just add an assigment and the glitches will not be transfered.
assign W = X;
@(posedge W)   solves the problem. :)
However, if I use
@(Y) sy=1;
@(!Y) sy=0;
then it works fine.
I have done a little more research and found that this pheonomena has been noticed by many,  is well known for long, and is due to how simulators handle time. However, if a simulator triggers a posedge/negedge event when there is no change in the signal, then I consider it a serious nasty bug. Sure there are ways to get around it, still..
I have a DUT that works fine on real HW. I am trying to run an official verification on each module in it, and do not want change my DUT just because the simulator is wrong. I do not think there is anything wrong with using default values at the beginning of an always block.
Dear Xilinx, what is your view on this?
Thank you
Miklos
Clearly, both codes are supposed to be same . I tried same code with vhdl and the problem persits. We have to be careful in such cases and work the alternative way. Interesting issue.
jagannath@logictronix.com
Participant blindobs
It's not a bug, and yes both codes will produce same rtl. This 'phenomen' is because of delta cycles in simulation:
    Y <= 0;
    if (cnt[3]) Y <= 1;
end
At each rising edge of clk your Y will be assigned 0 value at 1 delta cycle, and then '1' if cnt[3] in 2nd delta cycle. So in verilog Y timespace there is actually a glitch 1->0->1 (it's delta cycle so it's not seen on waveform thus i bealive there is switch to see delta cycles in simulators lie aldec), that's why your process @negedge is triggered.
Look at different waveform you will get if switched
end
to:
end
Anyway for VHDL and signals it should be fine i quess, different mechanism for passing values in simulation, though variables will act the same
Hi blindobs,
I understand what causes this, but the end result is just not OK.
The simulator should simply not consider a pulse of zero width as two edges, methinks.
To be honest simulator only catches one edge that's why there is pulse on output.
this code will give 'funny' waveform
end
as each line in block will get different schedule delta time.
TBH simulator caching 'zero' width pulses is usefull concept for logging different events in simulation time.
Anyway it's a really nice example, and maybe someone will post modelsim delta cycles of this testbench code. I currently got only Active-HDL restricted edition.
assign W = X;
Scholar dgisselq
@mbence76,
My own solution is to use non-blocking assignments in test bench code, rather than blocking assignments.  I've found more than one piece of nearly-inexplicable behavior that gets fixed by using non-blocking assignments.
The two aren't quite equivalent, so you might find yourself needing to make further adjustments to your code to use them, but the non-blocking assignments (followed by a clock edge of course) tend to be more robust.
Just my two cents,
Dan
