fbartra
Array signal updated by different procedures gives undifined simulation output value
I am using wedpack ISE, spartan 3
I have declared an array signal in my code as follows:
  • type Array256x8  is array (0 to 255)  of std_logic_vector(7 downto 0);
  • signal FpgaReg : Array256x8 := ((others => (others => '0')));
When simulating my code:
  • if at least one pointer to a address is a signal (not a fixed value, i.e. X"03" instead of my_value) then I get a "x" and "red colored waveform" when simulating this code
  • otherwise, if the pointer to all addresses are a fixed value then I get the right value when simulating this code
couldn't each address of this array be writen (modified) by different procedures?
There are no erros or warning when I compile my code
any suggestions?
Thank you
Fausto bartra
jmcclusk
Mentor
Mentor
Try switching your memory declaration from a signal to a shared variable.   That should get rid of the conflicts in simulation.
richardhead
 Please post the code, it is difficult to tell whats going on without a reference.
Points to note: In VHDL, each element of an array IS a separate object, so each element can be written from a separate process, unless there is a loop involved somewhere. BUT, this will NOT infer a RAM.
@jmcclusk A shared variable is only likely to mask the problem if there are multiple drivers in the code, and create race conditions during simulation. A shared variable should only be used if you are trying to infer write-first ram. Otherwise I highly recommend you use a signal, exactly for the reasons the OP is having problems with.
fbartra
Voyager:
thank you it works
Just one problem, ISIM does not support variable tracing
thanks
Fausto Bartra
fbartra
Richard:
here is my code: I have trimmed as much as I could to show where the problem is
two processes access the same array FpgaReg but different locations
Thank you in advance
--            MCU Interface
McuInterface: process(CLK)
begin
    if falling_edge(CLK) then
        if (bufMCU_CSn = '1') then        -- When CSn is HIGH, state machine gets reset
            FpgaReg(CONV_INTEGER(ADDR_FPGA_VERSION_HIGH)) <= VER_HIGH;
        else    -- CSn is LOW
            case McuState is
                when FpgaWrite =>
                                FpgaReg(CONV_INTEGER(FpgaAddress)) <= bufMCU_D_IN; <-- if FpgaAddress changed with a value, no problems
    end if;
end process McuInterface;
KpDebounce: process(CLK)
begin
    if rising_edge(CLK) then
        if P10ms = '1' then
            case KeypadDebState is
                when FoundKey =>
                    -- flag MCU
                    FpgaReg(CONV_INTEGER(KP_LED))(3 downto 0) <= LastKB; <-------------- this change shows as "X red colored waveform"
                when others =>
            end case;
        end if;
    end if;
end process KpDebounce;
richardhead
Ok, so the only answer here is to use a shared variable. What do you expect to happen when both processes write to the same address at the same time? The VHDL shows the correct behaviour with XXXs, as it has no idea which signal wins, so you will get XXX.
A shared variable will avoid the Xs, but you are at the mercy of a race condition on a write to both locations at the same time.
