Arrays/Records with unconstrained elements (2008)
When will this be supported?
ERROR: [XSIM 43-4187] File "...vhdl" Line 26 : The "Vhdl 2008 Record with Unconstrained Element" is not supported yet for simulation.
Re: Arrays/Records with unconstrained elements (2008)
For VHDL-2008, only a limited set of feauture is supported in Vivado Simulator. From your ERROR message, it seems that you have something like
_________
library ieee;
use ieee.fixed_pkg.all;
entity top is
end;
architecture arch of top is
begin
end;
_______
The moment you use 'fixed_pkg', it means that you are using package instantiation as fixed_pkg is nothing but instance of generic package like
_________
library IEEE;
package fixed_pkg is new IEEE.fixed_generic_pkg
generic map (
fixed_round_style => IEEE.fixed_float_types.fixed_round,
fixed_overflow_style => IEEE.fixed_float_types.fixed_saturate,
fixed_guard_bits => 3,
no_warning => false
_________
So those features, which are not supported, you should see ERROR message ID 43-4187. If your intention is not to use the fixed_pkg, please modify your test case.
can you check if the following AR helps
http://www.xilinx.com/support/answers/62005.html
refer chapter-5 in the following link
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug901-vivado-synthesis.pdf
also check appendix e  from the following link
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug900-vivado-logic-simulation.pdf
Thanks and Regards
Balkrishan
No, I'm intentionally using an unconstrained member of a record, and wondering when Xilinx will support it (and all of 2008).
I am still experiencing this exact same problem in Vivado 2018.3! This needs to be fixed...
@lsav
Interesting - because they work fine in synthesis, as of 2017.4. (I use ActiveHDL for simulation - I have code that I doubt will ever be supported in vivado)
Can you post the code you're trying to use?
@richardhead apologies, i meant this happens in behavoural simulation
@lsav
I understand this - but still, would be good to see the code Vivado is choking on. It seems odd there isnt parity between synth and simulation.
Absolutely! It is extremely annoying to have the same feature supported in synthesis and not in simulation!
Good luck,
based upon what we see, VHDL does not appear to be high on the Xilinx to do list.
Now if you were into a new thing like AI, then you might be in luck
