kuldipspx
CR 991325 Update Needed
I am using Xilinx Zynq VIP in my design simulation environment. I found that AXI_HP0 port doesn’t function correctly. AXI_HP0 has to assert the RVALID signal, But it never got asserted. I also searched the solution on the Xilinx Forums and found that many people has same problem as explained below in the following thread. I have asked the work around in the same thread But nobody from Xilinx replied.
 I need to get the work around for this problem in order to make progress on my project. Your urgent help is needed in this regard.
https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Zynq-7000-Verification-IP-S-AXI-HP0-doesn-t-assert-RVALID/m-p/814407/highlight/false#M17190
chrisz
Hello Kuldipspx,
This CR is still being investigated by the development team.
Chris
zyanwu
Hi @chrisz,
Any updates on this CR?
Z
chrisz
Hello @zyanwu,
The notes of the CR state that this issue is resolved in the latest version of Vivado.  I recommend upgrading to Vivado 2018.2.
Chris
