Clocking variable is read to -1 in submodule
My environment:
Windows 10 64-bit build 16299.248
Vivado 2017.4
When I run the behavioral simulation with the following code with Vivado Simulator 2017.4. I find the clocking variable cb.t is read to -1 sometimes. However, the signal t is unsigned.
`timescale 1 ns / 1 ps
module C(input t, input clk);
    default clocking cb @(posedge clk);
        input t;
    endclocking
    initial begin
        #0;
        forever begin
            @(posedge clk);
            $display("cb.t == %d", cb.t);
            if(cb.t == -1)
                $fatal(1, "Error!");
        end
    end
endmodule
module Tb;
    // Clock period.
    parameter real clk_p = 10;
    // Clock half period
    parameter real clk_hp = (clk_p)/2;
    // Delay for Xilinx FPGA GSR.
    parameter xilinx_gsr = 100;
    logic nreset;
    logic clk;
    logic t;
    initial begin
        nreset = 0;
        #xilinx_gsr;
        #(clk_p);
        nreset = 1;
        #300;
        $finish;
    end
    initial begin
        t = 0;
        #100;
        t = 1;
        #100;
    end
    initial begin
        clk = 0;
        #xilinx_gsr;
        @(posedge nreset);
        #8;
        forever #clk_hp clk = ~clk;
    end
    C c0(.*);
endmodule
The Tcl Console will show:
cb.t ==  x
cb.t == -1
Fatal: Error!
However, Synopsys VCS 2017.12 seems to correctly simulate the code and print these:
cb.t == 0
cb.t == 1
cb.t == 1
Is this a Vivado bug? If it is, please Xilinx fix it. Thanks.
hi @zxvc,
This seems to be the bug in Vivado simulator. Issue reported to the factory.
Sunilkumar
hi @zxvc,
Sunilkumar
Thank you.
Hi @zxvc,
As a work around, please update the module ports with datatypes mentioned below
module C(input logic t, input logic clk);
Design working as expected  with the above change.
Sunilkumar
Thanks. The workaround works.
