dimpy
Debug hub core in vivado
hello all,
I am working on the zc706 fpga board. I wrote the one code which is the power on off sequence code. I take 8 bit led as output. I have synthesized the design and after that i am trying to set up debug core. The debug core not detected all 8 bit output. There i am finding only  2 or 3 led for debugging.
Can you please explain me how it is showing like this?
Waiting for your response.
Thank you,
kdeshwal
Hi @dimpy ,
I believe debug_core is detected successfully and there could be some problem with the output data width.
Please share screenshots of the view to have clear visual of the issue.
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
