Disabled Simulation Option
I have two questions.
Firstly, I am trying to make a 4 bit counter on Vivado 14.3. I have realized that when i tried to simulate the VHDL code, the "Run Post-Synthesis Functional Simulation" and "Run Post-Synthesis Timing Simulation" options are disabled. Do you have any idea to enable them or is this a normal situation? I have shown below.
My second question is related to that when i am trying to add source, the "Next" button is disabled also. Do you have an idea about this or is it a normal situation. I have shown below.
Thank you.
For the first one. Have you synthesized your design? If not then first synthesize the design then those options will be enabled.
For the second one:
Have you selected the add files/ add directories/ create file. If you see all the files there then just click on finish. Once you select any of the options mentioned you will be able to see the respective next options.
HJ
Don’t forget to reply, kudo, and accept as solution. For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
For the second one:
HJ
check this ARs
https://www.xilinx.com/support/answers/63987.html
For ISE flow check this ARs
https://www.xilinx.com/support/answers/45668.html
Thanks and Regards
Balkrishan
