grenoble2007
EDK 92 vsim unisims_ver and verilog fails to simulate
I would like to simulate a design made with EDK 92i (SP2)  of ml405 based basic design
Unfortunately, the simulation fails du to the verilog module of the MPMC
I make a configuration of the top level that includes the design and here is the message I have
# vsim -L unisims_ver -L simprims_ver work.bench_cfg
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: /rech-fmr/mancini/EDK92/lib/ise92/unisims_ver/unisims_ver_source.v(60928): Failed to find 'glbl' in hierarchical name.
# Optimization failed
What's the trouble ?
Does it mean that unisms_ver_source.v is different from the VHDL code ????
What should I do to simulate this design ?
edv
To resolve this issue, make sure the globals source file is compiled.  This source file is located at:
%XILINX%/verilog/src/glbl.v
Edit your simulation script to the source code above is compiled.  It should resolve the error.
Hope this helps.
Eddie
