Visitor denbigh1974
ERROR: [Common 17-39] 'launch_simulation' failed due to earlier errors.
I am using Vivado v2016.1 (64-bit). My operating system is Linux Mint 18.3
When I run a simulation of my program I get the following error message:
followed by:
[USF-XSim-62] 'elaborate' step failed with error(s). Please check the Tcl console output or '/home/denbigh1974/Documents/Xilinx/20180205_project_wk1/project_2/project_2.sim/sim_1/behav/elaborate.log' file for more information.
 [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
When I look at elaborate.log it says:
Vivado Simulator 2016.1
Copyright 1986-1999, 2001-2016 Xilinx, Inc. All Rights Reserved.
Running: /opt/Xilinx/Vivado/2016.1/bin/unwrapped/lnx64.o/xelab -wto 149535b7a1c84875815e0e3d64a4d2a5 --debug typical --relax --mt 8 -L xil_defaultlib -L secureip --snapshot tutorial_tb_behav xil_defaultlib.tutorial_tb -log elaborate.log
Using 8 slave threads.
Starting static elaboration
Completed static elaboration
Starting simulation data flow analysis
Completed simulation data flow analysis
Time Resolution for simulation is 1ps
Compiling package std.standard
Compiling package ieee.std_logic_1164
Compiling package ieee.std_logic_arith
Compiling package ieee.std_logic_unsigned
Compiling package std.textio
Compiling package ieee.std_logic_textio
Compiling package unisim.vcomponents
Compiling architecture behavior of entity xil_defaultlib.tutorial [tutorial_default]
Compiling architecture behavior of entity xil_defaultlib.tutorial_tb
ERROR: [XSIM 43-3409] Failed to compile generated C file xsim.dir/tutorial_tb_behav/obj/xsim_1.c.
ERROR: [XSIM 43-3915] Encountered a fatal error. Cannot continue. Exiting...
I'm a beginner. I have to use version 2016.1 to match the version at university.
Please could you suggest a solution to my problem?
Thank you.
Scholar austin
Re: ERROR: [Common 17-39] 'launch_simulation' failed due to earlier errors.
Run on a supported OS.
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi @denbigh1974,
Can you please try your design with latest version of Vivado(2017.4). Please share your design if you are facing the same issue with latest version of Vivado.
Sunilkumar
Visitor denbigh1974
I should add that, even though the log file contains the line
the xsim_1.c file has been created.
Scholar austin
https://www.xilinx.com/support/answers/54242.html
Your OS is not supported (Mint)?
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor denbigh1974
Thank you for your fast reply.
"Can you please try your design with latest version of Vivado(2017.4)"
Presumably, I have to uninstall 2016.1 and get new licence to do this?
My problem is that I have to also transfer my design files to another system running Vivado 2016.1 under Windows. I don't think that the files in 2017.4 will be backward compatible?
Is there anything else I can try first or do you think it's a bug?
Scholar austin
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor denbigh1974
I am now running Vivado v2016.1 successfully on Ubuntu 14.04.5
Thank you for your assistance.
Scholar austin
Fantastic!
Thank you for letting us know that was the issue.
Austin Lesea
Principal Engineer
Xilinx San Jose
this error arises on my computer also and i use vivado(2018.2) on window10.
launch_simulation
INFO: [Vivado 12-5682] Launching behavioral simulation in 'C:/Users/rajni/project_DCO/project_DCO.sim/sim_1/behav/xsim'
INFO: [SIM-utils-51] Simulation object is 'sim_1'
INFO: [SIM-utils-54] Inspecting design source files for 'dco_pll' in fileset 'sim_1'...
INFO: [USF-XSim-97] Finding global include files...
INFO: [USF-XSim-98] Fetching design files from 'sim_1'...
INFO: [USF-XSim-2] XSim::Compile design
INFO: [USF-XSim-61] Executing 'COMPILE and ANALYZE' step in 'C:/Users/rajni/project_DCO/project_DCO.sim/sim_1/behav/xsim'
"xvlog --incr --relax -prj dco_pll_vlog.prj"
INFO: [VRFC 10-2263] Analyzing Verilog file "C:/Users/rajni/project_DCO/project_DCO.srcs/sources_1/new/dco_pll.v" into library xil_defaultlib
ERROR: [VRFC 10-452] cannot open include file constant.v [C:/Users/rajni/project_DCO/project_DCO.srcs/sources_1/new/dco_pll.v:22]
INFO: [VRFC 10-311] analyzing module dco_pll
ERROR: [VRFC 10-2787] module dco_pll ignored due to previous errors [C:/Users/rajni/project_DCO/project_DCO.srcs/sources_1/new/dco_pll.v:25]
INFO: [USF-XSim-69] 'compile' step finished in '3' seconds
INFO: [USF-XSim-99] Step results log file:'C:/Users/rajni/project_DCO/project_DCO.sim/sim_1/behav/xsim/xvlog.log'
ERROR: [USF-XSim-62] 'compile' step failed with error(s). Please check the Tcl console output or 'C:/Users/rajni/project_DCO/project_DCO.sim/sim_1/behav/xsim/xvlog.log' file for more information.
ERROR: [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
Hi rajni@dadri32,
Can you please create a new thread for your issues. You can check if the below Answer Record helps:
https://www.xilinx.com/support/answers/56494.html
Thanks & Regards,
Sravanthi B
Visitor cthalxy
Hi, when I run a project on vivado(vivado 2018.2 on windows10 OS), I also face this errer: [Common 17-39] 'launch_simulation' failed due to earlier errors.
I wonder what the reason is and how to solve this problem.
Many thanks.
Newbie mrmarwan16
Hello!. I had that same error after a problem in a simulation. After that mistake, every time I tried, I continued to appear. What I did was close the program, delete the files in the simulation folder of my project, when starting the program, the error disappeared.
I use Vivado 2019.1 in Windows 8.1
Hi all,
I had the same error message.
It occured because I still had an unconnected port of my IP core within my vhdl code.
So it seems, that this error message can have multiple reasons.
I just wanted to mention that in case anyone else has that error.
Kind regards
