flydolf12
ERROR:Simulator:861 - Failed to link the design
hi
i'm a very new student user of xilinx 14.2 design tool who just used it 2 weeks.
this week i should do "Simulate Behavioral Model" but i can't....
just i saw below messages.. and i don't know what is the matter.
Started : "Simulate Behavioral Model".
Determining files marked for global include in the design... Running fuse... Command Line: fuse -intstyle ise -incremental -lib unisims_ver -lib unimacro_ver -lib xilinxcorelib_ver -o {E:/2012_fall_ISE Project/3rd week/1bit full adder/full_adder1/full_adder1_TB_isim_beh.exe} -prj {E:/2012_fall_ISE Project/3rd week/1bit full adder/full_adder1/full_adder1_TB_beh.prj} work.full_adder1_TB work.glbl {} Running: C:\Xilinx\14.2\ISE_DS\ISE\bin\nt\unwrapped\fuse.exe -intstyle ise -incremental -lib unisims_ver -lib unimacro_ver -lib xilinxcorelib_ver -o E:/2012_fall_ISE Project/3rd week/1bit full adder/full_adder1/full_adder1_TB_isim_beh.exe -prj E:/2012_fall_ISE Project/3rd week/1bit full adder/full_adder1/full_adder1_TB_beh.prj work.full_adder1_TB work.glbl ISim P.28xd (signature 0x1048c146) Number of CPUs detected in this system: 2 Turning on mult-threading, number of parallel sub-compilation jobs: 4 Determining compilation order of HDL files Analyzing Verilog file "E:/2012_fall_ISE Project/3rd week/1bit full adder/full_adder1/half_adder1.v" into library work Analyzing Verilog file "E:/2012_fall_ISE Project/3rd week/1bit full adder/full_adder1/full_adder1.v" into library work Analyzing Verilog file "E:/2012_fall_ISE Project/3rd week/1bit full adder/full_adder1/full_adder1_TB.v" into library work Analyzing Verilog file "C:/Xilinx/14.2/ISE_DS/ISE//verilog/src/glbl.v" into library work Starting static elaboration Completed static elaboration Fuse Memory Usage: 104956 KB Fuse CPU Usage: 327 ms Compiling module half_adder Compiling module full_adder Compiling module full_adder1_TB Compiling module glbl Time Resolution for simulation is 1ps. Waiting for 3 sub-compilation(s) to finish...
Process "Simulate Behavioral Model" failed
i've obeied the procedure in my reference but not working.
so i re thought and re did but don't know why..
in my friend's computer with OS windows 7, that works well with same source but not mine..
hmm..by any chance, doesn't xilinx 14.2 support OS windows 8 yet??
my OS is windows 8 32bit enterprise k RTM ver.
is this a OS compatibility problem or just my mistake in doing my procedure??
i want to know if there is anyone whose OS is windows 8 and Isim works well!!!
i can't find about 'operating xilinx in windows 8' in my country's sites.
please tell me :)
P.S.  sorry for my poor English, i don't know english well 'cause i'm Korean,
if i could use Korean, I would say what i think and want more concretely..ㅠㅠ
anyway thanks for reading..& please reply if you knows~
chavez8121
Perfect fix for me. Thank you very much!
rakesh_ind
Probliem Solved
(1) First download MinGW latest version
(2)Then Copy all contene from MinGW from C
(3)And Paste these into E:\Xilinx\14.2\ISE_DS\ISE\gnu\MinGW\5.0.0\nt
----> In my case i have installed xilinx in E ; For U this may be different
(4)No check the problem will be solved
yuvi108032
pls solve my problem
evanomar15
HI,
I am very new to using this program as a student, and when i try to simulate everytime i get 861 Error , I am running W8 32bit i my computer is there anything I could do to fix it.
Anonymous
Not applicable
I've tried in compatibility mode with W7 but it doesn't work well.
Do you have any solution for this problem?
Ricardo
c150186.learn
@lishunan246 wrote:
This is because the MinGW that ISim uses doesn't work with Windows 8. Consider install a new version of MinGW and paste it to C:\Xilinx\12.4\ISE_DS\ISE\gnu\MinGW
thanks it worked
gaurav_acad
permanent solution 1: on win 10
Find the "installation directory \ Xilinx \ 14.x \ ISE_DS \ ISE \ gnu \ MinGW \ 5.0.0 \ nt \ libexec \ gcc \ mingw32 \ 3.4.2 \ collect2.exe" and delete it and re-run the emulator, the problem resolved! !
ya don't worry just delete this or cut and paste somewhere as else, now re run the code or test bench it will work.
keep on coding and sharing
please accept the solution if find working
No need to update any minGW
apostolis
gaurav_acad your solution worked fine for me.. thank you very much!
I followed the path you described and deleted the collect2.
I'm using a 32 bit windows 10 (automatically upgraded from win7 by microsoft) and ISE 14.7
warntresk
it worked, thanks ALOT!
hardwareheini
The solution from gaurav_acad worked perfectly for me. I am on Windows 10 using PlanAhead. Even a minimal testbench example gave me a "Not Linkable"-Error. Deleting "collect2.exe" did the trick: ISIM is now starting.
xilinxtuhin
It is working now.
akarsh98
gaurav_acad your solution worked on win 8 too. thanks.
realistic
thank you so much my friends ıts working perfectly
umang885
I recently installed ISE 14.7 on my windows 10 laptop. I write a simple code for 3 input xor gate and could synthesize rtl and technology schematic but unfortunately could not simulate the behavioral model using ISim Simulator.
It was showing the above-stated error.
I have also linked matlab 2013b with xilinx system generator.
Please help me out asap; I have a mini project to be submitted next week.
whatsupflip
Dragon here,
This solution work on windows 10 and i tried on a HP PC Gaming Comp.
hiep.lqdu
Well, I use ISE 14.7 in windows 10. If you want simulate your project, you should try the 64-bit Project Navigator. But it is not convenient, you have to crack this program.
Step 1: Open your installation folder: Xilinx\14.7\ISE_DS\ISE\lib\nt64
Step 2: Find "libPortability.dll" and rename to "libPortability.dll.orig"
Step 3: Copy "libPortabilityNOSH.dll" to same folder and rename it to "libPortability.dll"
You will have 3 files in this folder "Xilinx\14.7\ISE_DS\ISE\lib\nt64"
- libPortability.dll.orig
- libPortabilityNOSH.dll
Step 4: Find the folder: "Xilinx\14.7\ISE_DS\common\lib\nt64" and do Step 2 and Step 3
P/S: You can watch this video to crack, however it is Vietnamese Tutorial https://www.youtube.com/watch?v=nRNvcoQkF6M
gaurav_acad
hi friend If you want to link system generator , you may have issues reason;
First: At the time of installation if you don't have compatible MATLAB version for ISE
Second : if MATLAb is not installed a time of Xilinx installation.
In both the case find the compatible version and then open start menu, right click on system generator icon to configure matlab and using run as Admin. configure the setting.
gaurav_acad
solution @Anonymousno need to downgrade, just see my original post to get rid of the error
Please mark that as solution, downgrade is not required.
fredjobsearch
I had the same running isim problem with Xilinx-ISE under Windows 10..
I'm not using any screwy mingw or whatever that Linux emulation some people seem to be using is in the comments.
And I got it to work!!
Noticed there is a nt and nt64. Check the path by right clicking on the ISE Design Suite 14.7 icon.
Target Path : C:\Xilinx\14.7\ISE_DS\settings64.bat C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\ise.exe
Notice the "nt64".. it was "nt" after installation... and isim had the 861 error.
When I ran it with the "nt64" running the executables.. scripts or whatever in the nt64 directory it worked when I ran isim.
Compiling and everything seemed to work fine in the /nt/ directory(but not isim)..
Why wouldn't it default set it to /nt64/ directory since it is a 64-bit system.
Since these days everything is 64-bit I speculate maybe they don't bother to test the 32-bit versions as much so miss more errors... But that is just speculation.
From the [help]-[about] it shows if it is /nt/ or /nt64/.
So if you are running /nt/ and isim gives the 861 error try /nt64/..
Rebuilding-ALL might not hurt in implementation and redo all simulation.. probably won't help either but might as well if things are failing.
If this helps anybody. No thanks necessary. Please send me money.., lots of money.
asiwarski1
Huge help my friend!  Prior in doing this work-around, I had no luck running the 64bit version on Windows 10. I had given up and just used the 32bit version.  I tried to sim a project in the 32bit version and got the 861 error and begun digging.
One quick tweak I did because I didn't have libPortabilityNOSH.dll in C:\Xilinx\14.7\ISE_DS\common\lib\nt64.  In this directory...
I renamed libPortability.dll to libPortability.dll.orig and copied libPortability.dll and libPortabilityNOSH I created in step 2 & 3 located in C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64 to C:\Xilinx\14.7\ISE_DS\common\lib\nt64 so I had a 3 files.  So far this has worked great!!!  Really appreciate the info!
abyasser6
Life savior, thanks a lot
Deleting collect2.exe does not work for me.
ise version-14.7
windows 10, 64bit. No antivirus used.
aliebrmy
thanks a lot :))))))))
