Nico5
ERROR: [XSIM 43-3409] Failed to compile generated C file xsim.dir/fft32_tb_behav/obj/xsim_1.c.
Hello.
I am new in VIVADO and VIVADO HLS, and I am having troubles in "Simulation" stage.
The Message console says [USF-XSim-62] 'elaborate' step failed with error(s). Please check the Tcl console output or '/home/nicolas/Documents/VIVADO/FFT_32/project_1/project_1.sim/sim_1/behav/xsim/elaborate.log' file for more information, then I opened the elaborate.log file and found the error in the title.
I attached my xsim_1.c file.
I am running VIVADO 2019.2 on Ubunt 20.04.
Thanks!
sunilku
Hi @Nico5 ,
Can you please share the design for further debug.
Sunilkumar
Nico5
Hi @sunilku , thanks for your help!
I am not sure which is the file that contains the design, but there is design_1.tcl file and I hope this is the one.
In order to resolve the issue, I append ftt.cpp, this is a file that I use in VIVADO HLS to create an IP_Core, and datasrc.v, datasrc_tb.v.
Thanks!
Nico5
@sunilkuI have open and example project and the I tried to run the simulation, in order to verify if my design was bad, but there was the same issue.
sunilku
hi @Nico5 ,
With the shared files, I am not able to reproduce the issue. Can you please share the generated Vivado project if possible?
And also please share the OS details also.
Sunilkumar
harikade
Please try running design by adding the switch '-cc clang' to xelab command.
Harika.
