ERROR:add_1 must be in range [-1,DEPTH-1]
I'm working on filter design on Vivado 2017.4. I'm using DDS for generating sine wave and giving it to FIR compiler .
When I tried simulating , I'm getting the error which I'm attaching in the snapshot below.
Can u please help me out in solving this error.
Thanks and regards,
Akshay M
Re: ERROR:add_1 must be in range [-1,DEPTH-1]
Hi @akshay_iyngr95
Please share the project or test case to look into this further. Also try in latest tool version 2018.1 once.
Rohit
Rohit
Hi @akshay_iyngr95,
Can you please check if the following posts helps:
https://forums.xilinx.com/t5/Simulation-and-Verification/vivado-2015-1-simulation-error-Failure-ERROR-add-1-must-be-in/td-p/600653
https://forums.xilinx.com/t5/Simulation-and-Verification/vivado-simulation-block-memory-module-failure/td-p/646336
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
Hi, @bandi
I tried changing the clock stimulus but it didn't work.
The valid signal to fir compiler is given from dds compiler and the files are encrypted in IP.
I'll be sharing the project files soon.
Thanks and regards,
Akshay M
Hi, @thakurr
Thanks and regards,
Akshay M
Hi, @thakurr
I'm attaching my project tar file below. please have a look into it.
Thanks and regards,
Akshay M
Hi @akshay_iyngr95,
File test_design_fir.v is missing from the shared project. Because of the missing file we can't move further. So, can you please share the complete archived project. To archive the project click on File --> Archive Project in Vivado
Hi, @shameera
Sorry for that.
I'm attaching the archived files of my project below.
Thanks and regards,
Akshay M
It looks the M_AXIS_PHASE_0_tready is not initialized.
I tried to assign an initial value to it in the testbench and the error was not seen.
wire  M_AXIS_PHASE_0_tready = 1'b1;
@graces
Interesting. Is there a way for Xilinx to make that error traceable? I was able to quickly resolve through this thread, but the error itself can't be traced. I found it after I added tready to an axis interface and forgot to hook it up.  Same error.
Thanks for the post providing a quick solution.
The error message is coming from the assertion in AXI SRL FIFO (encrypted) used within the IP core.
This kind of failure is typically seen when master and slave AXI are not initialized. e.g. when the slave TVALID and TDATA are in an 'U' or 'X' state.
The unknown or undefined state applied to the core cause the assertions in the AXI SRL FIFO to be triggered, which terminates the simulation.
@graces
Yes I understand where it came from, and it was clear from your analalysis of the OP's code how to correct the simulation failure. All I am saying is that this simulation failure didn't trace to an obvious and simple solution. I ask that Xilinx considering providing the traceability to ease debug.
The IP source is encrypted and therefore not traceable.
We can document an answer though, to provide the solution to this error and avoid duplicate effort.
Ah ok, I didn't know why it was not a traceable simulation failure. Understood, thanks.
