Endless elaborating process in iSim
I am trying to run my 3bit counter based on flip-flops D using iSim.
Unfortunately when i run process of iSim behavioral simulation the never ending elaborating message appears each time.
All projects are 100% working during clases and i wanted to check how it works in home but I'm unable to simulate them.
Test bench is fine, schema also correct - only iSim is having troubles.
The instalation is fresh - ISE WebPack 14.7, with new licesne file etc. Moreover the same copy was installed by my friend and works perfect on his computer. I've also left all default options during installation, I have Levovo T430 with Core i5, 8GB of RAM and SSD with Win7 64bit.
Thanks in advance for every answer, I have no idea whats going on.
Cheers
Re: Endless elaborating process in iSim
I've just solved my problem with endless elaboration process. Well, you'll never guess ;))
It is worth to check whether your firewall or antivirus is blocking your iSIM simulation process..
Thanks for help
Topic undoubtedly for closing
Thanks for help
Hi @mackoks,
It is good to know that you found the resolution for issue.
Please mark your post as "Accept as solution" so that it will help the other forum users to directly refer to the answer.
Tushar
