Error - Wavedata 42-52
I got this error everytime when I start a simulation:
How can I fix this problem?
Thank you for help!
Re: Error - Wavedata 42-52
If that is the case, try below steps:
1. In Project sources window, are you observing the VG_Ctrl.wcfg file?
2. If yes, right click on it and select disable file
3. Run simulation
Vinay
The error messsage clearly indicates that VGA_Ctrl.wcfg is already open.
Close the simulation window and rerun the simulation.
Vinay
Thank you. I have tried this before, but it doesn´t solve the problem :(
3. Run simulation
Vinay
Visitor paulatvti
I had the same error.  To fix this problem, I closed down Vivado, manually deleted all of the wcfg files, then re-opened the project and removed the wcfg files (that Vivado can not find since I deleted them) from the project.  This worked for me.
I've had a similar problem ... repeated attempts to open the same wcfg file, ... and I tried getting rid of it by removing the reference to it from Vivado Project Manager Sources window. When this didn't work I tried the suggestion above and deleted all wcfg files from the project folder and below ...
... but the tool now complains about the missing files.
WARNING: [USF-XSim-17] WCFG file does not exist:C:/project/attic_packed_samples/sim/attic_packed_samples_wrap_TB_behav.wcfg
Can anyone help, please
PaulD
Did you set option "-view <file path>/attic_packed_samples_wrap_TB_behav.wcfg" in xsim.simulate.xsim.more_options field?
Hi graces,
Thanks for your suggestion. I've looked and there are no entries in the xsim.simulate.xsim.more_options field.
So I've editted the project .xpr file directly to remove the two duplicate lines in the section shown:
      <Config>
        <Option Name="DesignMode" Val="RTL"/>
        <Option Name="TopModule" Val="attic_packed_samples_wrap_TB"/>
        <Option Name="TopLib" Val="xil_defaultlib"/>
        <Option Name="TopAutoSet" Val="TRUE"/>
        <Option Name="SrcSet" Val="sources_1"/>
        <Option Name="XSimWcfgFile" Val="$PPRDIR/sim/attic_packed_samples_wrap_TB_behav.wcfg"/>
      </Config>
... and this cures the problem!
PaulD
Newbie mikecwilk
Thanks prdorrell,
This is the correct answer just edit the project .xpr file. Hopefully it is fixed in 2014.5. Im still using 2014.4.
Hi mikecwilk, I'm glad my hacking workaround has helped some else ... My post was from earlier this year when I still used Vivado 2014.3. Since then, I've upgraded to 2015.1 ... and haven't seen this problem again ... so maybe Xlinx have fixed it. Kind regard prdorrell
