Visitor l.narayanan
Error during Elaboration in NCSIM
My design compilation completed succesfully.
It is using the Xilinx Library files i have provided the path of the secureip for GTX Wrapper.
During the state of elaboration i have *E,DUPTOP and following error message.
*E,CUVMUR related to srio.v.
I am trying to simulate the Xilinx example design SRIO for Kintex-7.
Thanks for your time.
Re: Error during Elaboration in NCSIM
Please post the complete error message given by tool.
Thanks,Vijay
Visitor l.narayanan
ncelab: *F,DUPTOP: duplicate top-level unit names:
ncverilog: *E,ELBERR: Error during elaboration (status 2), exiting.
This is error message i am using the single step script with cds.lib and hdl.var for the library mapping compiled with compxlib.
Attach your simulation script here.
Visitor l.narayanan
Please find the below script and related files which i have used for the simulation.
#script.sh
#!/bin/sh
rm -rf ./INCA_libs/*
ncverilog -y $XILINX/verilog/src/unisims\
/tools/ISE_DS/ISE/secureip/ncsim/gtxe2_channel_ncsim/gtxe2_channel_001.vp\
/tools/ISE_DS/ISE/secureip/ncsim/gtxe2_channel_ncsim/gtxe2_channel_002.vp\
/tools/ISE_DS/ISE/secureip/ncsim/gtxe2_common_ncsim/gtxe2_common_001.vp\
/tools/ISE_DS/ISE/secureip/ncsim/gtxe2_common_ncsim/gtxe2_common_002.vp\
-timescale 1ns/1ps\
+incdir+$XILINX/verilog/src +libext+.v $XILINX/verilog/src/glbl.v\
-f vfile.f -64bit
vfile.f contains the compilation files form the xilinx IP generated files.
#cds.lib
INCLUDE /cad/cadence/INCISIV12.10.007/tools.lnx86/inca/files/cds.lib
define worklib ./worklib
define ip_lib ./ip.lib
DEFINE secureip /tools/14.4/ISE_DS/ISE/verilog/ncsim/10.20-s119/lin64/secureip
DEFINE unimacro /tools/14.4/ISE_DS/ISE/vhdl/ncsim/10.20-s119/lin64/unimacro
DEFINE unisim /tools/14.4/ISE_DS/ISE/vhdl/ncsim/10.20-s119/lin64/unisim
DEFINE unisims_ver /tools/14.4/ISE_DS/ISE/verilog/ncsim/10.20-s119/lin64/unisims_ver
DEFINE unimacro_ver /tools/14.4/ISE_DS/ISE/verilog/ncsim/10.20-s119/lin64/unimacro_ver
DEFINE simprim /tools/14.4/ISE_DS/ISE/vhdl/ncsim/10.20-s119/lin64/simprim
DEFINE simprims_ver /tools/14.4/ISE_DS/ISE/verilog/ncsim/10.20-s119/lin64/simprims_ver
DEFINE xilinxcorelib /tools/14.4/ISE_DS/ISE/vhdl/ncsim/10.20-s119/lin64/xilinxcorelib
DEFINE xilinxcorelib_ver /tools/14.4/ISE_DS/ISE/verilog/ncsim/10.20-s119/lin64/xilinxcorelib_ver
#hdl.var
define verilog_suffix ( .v, .vr, .vb, .vg )
define vhdl_suffix ( .vhd, .vhdl )
define LIB_MAP ($XILINX/verilog/src=> ip_lib, + => worklib )
Please refer to the following AR on simulating secureip design with Vivado.
http://www.xilinx.com/support/answers/31060.htm
If you have compiled simulation libraries with Compxlib, you can reference the libraries with -libname switch in ncelab command without compiling the .vp.
