Error while Compiling Simulation libraries to Aldec Riviera pro
Created a design in Vivado 2018.1 and Compiled the Simulation libraries to Riviera Pro 2018.1 and got the below errors.
Compiling verilog library 'audio_tpg_v1_0_0'...ERROR: [Common 17-180] Spawn failed: No such file or directory
ERROR: [Common 17-180] Spawn failed: No such file or directory.
I have checked the audio_tpg_v1_0_0 folder and all required files are present still it is giving the same error.
Please do the needful.
Thanks in advance.
graces
For Vivado 2018.1, the compatible Aldec Riviera Pro version is 2017.10. It would be best to try out in compatible version to avoid unexpected issues.
Hi Graces,
Thanks for the reply.I have changed my vivado version to 2019.1 as it iscompatible with my Riviera Pro. After that i have exported my xilinx design HDL files and Compiled libraries to Riviera Pro.
Now how do i import the .elf generated using Xilinx SDK to other simulators like Riviera Pro from vivado.
Thanks in Advance.
graces
What simulation would you like to perform? For hardware simulation, you can run export_simulation (Vivado tcl command) to export a simulation script of the current design for supported 3rd party simulator.
