Error while simulating CAM reference design
I have customized CAM reference design provided in XAP1151. When trying to simulate the design, I'm getting the following error.
:HDLCompiler:410 - "N:/O.40d/rtf/vhdl/src/unisims/primitive/RAMB16BWER.vhd" Line 599: Expression has 72 elements ; expected 36
Teacher muzaffer
Re: Error while simulating CAM reference design
This means you made a mistake while customizing the design. The problem relates to port of a memory which is 36 wide only but you are somehow connecting 72 elements to it. You should instantiate another memory block and connect half of the 72 pin bus to the new memory.
