harinaban
Errror During Simulation
Hi Guys,
I am usiing Xilinx 9.2i for the past 4 months,Intially it was ok but now a days I am getting erro in simulation.
I have uploaded the image.
Plz look to this and give me a solution.
Thanks in advance.
vemulad
I dont see any error in the snapshot. There is only one message which says that you are using webpack license. Please give the error details.
Deepika.
Deepika.
vijayak
Is that the same project files which were working before and you are seeing error all of a sudden? Review what changes you have made and refer to the simulation log to see what is causing the issue.
Thanks,Vijay
pulim
Are you referring to the message "This is a Lite version of ISE simulator"?
the message will be shownup if youa re using ISE webpack license.
With the webpack license ISim will run in lite mode.
ISE Simulator Lite is a limited version of the ISE Simulator. There is only one limitation. When the user design + testbench exceeds 50,000 lines of HDL code, the simulator will start to derate the performance of the simulator for that invocation.
ashishd
You can check below link to know more about ISE simulator
http://www.xilinx.com/products/design_tools/logic_design/verification/ise_simulator_faq.htm
Ashish
harinaban
yes,I understood but my HDL code is not more than 10 lines then why this message is appearing.
I will show you the difference previously I was able to get the output see the screen shot.
But Now
Thanks in Advance.
vuppala
Can you share your HDL code here?
Vinay
anusheel
Can you please elaborate your query in terms of simulation results mismatch and expected output?
Anusheel
Helpful answer -> Give Kudos
vijayak
Hi @harinaban
Post the code if you want us to help you. If you already resolved the issue, please post the solution in the interest of other users.
Thanks,Vijay
