Anonymous
Not applicable
Execute simulation step stuck
I have W10 Eduction installed, and tried to simulate the BFT sample. Indepenant of which version of Vivado is use (2015.x, 2016.x or 2017.x) it never finished the "execute simulation step"
I tried the same on a W10 Pro machine, and all ran without problems.
Any clues what could be the problem?
Thanks in advance
Hi @Anonymous,
Good news. Could you mark this issue as solved?
Florent
Florent
Hi @Anonymous,
Do you have the same right on both machine? Could it be that the toll does not have the right to create files in a folder?
Florent
Florent
Anonymous
Not applicable
I'm admin on both machines. Nevertheless I will check, Any specific folder I should check?
Hi @Anonymous,
I would check the xilinx installation path, the folder from where you are launching vivado and the project folder.
Florent
Florent
Anonymous
Not applicable
I solved the issue by disabling my virusscanner (during installation and simulation). I'm using AVG.
I've I re-enable the virusscanner, simulation will not run.
Hi @Anonymous,
Florent
Florent
I've just run into the same issue : Vivado 2018.1 simulation won't run with AVG anti virus on - it just hangs.
Ok I can turn off anti virus to make it work.
I see this is marked as solved. Well there is a workaround but it is not really solved.
Is the issue with Xilinx or AVG? Surely one of these needs fixing to really solve the issue?
Just to add...
As I found Xilinx simulator gets stuck with AVG antivirus turned on, I swapped to using Avast antivirus. Initially I got good results, but today I found the simulator also got stuck with Avast turned on and needed to be disabled.
On my work machine I use eset antivirus without issue - but it seems both AVG and Avast are not compatible with the Xilinx simulator - would be good to know if Xilinx are going to fix this or not.
This is still an issue and will raise as new topic to see if I can get a response
I see, and do you know how to stop virusscanning?
