ldm.eth
[Export Simulation] bash script -> how to run under Windows?
Hi All,
When I Export files for Simulation (File -> Export -> Export Simulation), a script file <top_sim_name>.sh is created (among other scripts).
But, this is a bash script. But I'm using the simulator (Questa), which is under Windows OS (Win10).
So, how make this script being compatible to the Windows (bash environment is not a part of Win OS).
Thank you!
graces
There should be 3 separate DO scripts along with the .sh which you can run in Modelsim.
compile.do
elaborate.do
simulate.do
