FFT Core Vivado Simulation
I get an error when add fft test bench(vivado generate) vhd file into my sim sources. And fft ip core marked as red question.
How can i fix this problem? Or how can i add auto generate tb into my project.
Re: FFT Core Vivado Simulation
I suppose ; the problem is about the wrapper.
Auto generated test bench file instantiate design_1_xfft_0_0 not wrapper.
Both wrapper and tb instantiate design_1_xfft_0_0. Become circular reference problem.Beacuse of top level is wrapper not tb.
If you make hdl project not block design. You can test tb and fft core. it works!!
can you please share design file . It seems project not finding file . You may regenerate the IP
Thanks and Regards
Balkrishan
I did that;
1) Add FFT Core to BD
2) Generate Wrapper
-> It automatically add all desgin sources(wrapper,bd,..)  to sim sources
3) Generate Block Design
-> It generates a sim test bench inside working folder
4) Add test bench to sim sources
