zhengyudennis1
Failed to find the 'modelsim' simulator executable during the use of compile_simlib
Hi all,
   I want to use modelsim for functional simulation. Modelsim requires the complied library. When I used the command compile_simlib to simulate it, the error "Failed to find the 'mdelsim' simulator executable" shows. I think it maybe a problem about setting. How it can be solved? Thanks much for the help.
arpansur
Hi @zhengyudennis1,
1. You have to set the modelsim installation path in Tools->options->General->modelsim install path.(see the attached snapshot)
2.  Check for the compiled library location in the simulation settings.(snapshot attached)
Arpan
Arpan
arpansur
Hi @zhengyudennis1,
Arpan
Arpan
zhengyudennis1
   Thanks much for the reply. Do you mean that I should install modelsim separately and vivado does not have it?
arpansur
Hi @zhengyudennis1,
Install modelsim for it. We support specific versions of modelsim in each release. Check the supported versions before installation.
Arpan
Arpan
zhengyudennis1
OK. Thanks.
