Observer yizhao.cheng
Help for cadence IES Tool path setting problem in centos7
  I want to compile code in non-project vivado mode with centos7, but I meet a problem like below:
  INCLUDE $CDS_INST_DIR/tools.lnx86/inca/files/cds.lib
  How can I set CDS_INST_DIR path, the Cadence Incisive Enterprise Simulator (IES) is Integrated in the Vivado IDE, but I can not find the path, is it need to download and install in centos7 alone, if needed, how can I get IES software?
回复: Help for cadence IES Tool path setting problem in centos7
Cadence Incisive Enterprise Simulator (IES) is a 3rd party simulator. It can be set to be launched from Vivado IDE, however, it's not an integrated simulator with Vivado.
If you would like to simulate with IES, you need to download the simulator from Cadence and install it separately. The CDS_INST_DIR is an environment variable pointing to the install directory of IES.
  Thank you very much, I got it.
best regards,
yizhao
