acgropp1
Help understanding what this error code means
Hello, I am trying to simulate my design and I get this error. The design is a mixture of VHDL and Verilog. I get the following error when trying to simulate.
[XSIM 43-3253] File C:/Program Files/Opal Kelly/FrontPanelUSB/FrontPanelHDL/XEM7010-A50/okCoreHarness.v, line 9964. Verilog alias ports are not supported in mixed language simulation.
What is this referring to?
Thank you
Adam
thakurr
@acgropp1
Refer the below link for restriction of Mixed language with Vivado simulator:
https://www.xilinx.com/support/answers/64050.html
Rohit
Rohit
amaccre
Hi @acgropp1,
There is a list of what is supported in Mixed Language Simulation in Appendix G of User Guide 900 (attached).
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
